O-2 Sensor Question
Old Jul 11, 2002 | 02:13 PM
CptMorgan's Avatar
CptMorgan
Default O-2 Sensor Question
How often should an O2 sensor be changed? What are the signs of a bad O2?
Old Jul 11, 2002 | 02:16 PM
scorp508's Avatar
scorp508
I honestly don't know of an "interval". The signs of one could be some loss of power and definitley lower gas mileage.
Old Jul 11, 2002 | 02:38 PM
CptMorgan's Avatar
CptMorgan
Default Re: O-2 Sensor Question (CptMorgan)
My vette has 80,000 miles on it and I don't know if the O2 has ever been changed. I'm sure it hasn't been changed in the last 35,000 miles.
Old Jul 11, 2002 | 02:40 PM
scorp508's Avatar
scorp508
I would change it then just to be sure and get a starting point.
Old Jul 11, 2002 | 03:07 PM
C4-Wolf's Avatar
C4-Wolf
Default Re: (scorp508)
If you've notice your average mpg going down, or you feel that it is low right now, it might be time. Many people get 18+mpg for pretty much city driven cars.
Old Jul 11, 2002 | 03:14 PM
kaiser's Avatar
kaiser
Basic info on O2 sensors here:
http://www.parttrackers.com/library/1/
Section 3.03.
Old Jul 11, 2002 | 03:30 PM
pascualjr's Avatar
pascualjr
I changed mine at about 105k. I started getting lousy mileage - 13-15 mpg. Now it's back to the normal 18-20 mpg. :seeya
Old Jul 11, 2002 | 03:43 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Use a paper clip to jumper ALDL pins A&B, start the engine and wait until the SES flash rate drops to about 1HZ. Then the On/Off duration indicates rich/lean condition. Rev the engine to about 2,000rpm, hold for a copla seconds and notice the SES flashes.
If the SES On/Off durations are about equal and about 1Hz the ECM is in closed loop mods and the O2 sensor is fine.
Of course a scan tool is the easy way to see.
To O-2 Sensor Question
