valve stem seal ...
Old Jul 11, 2002 | 02:13 PM
wilhelm86's Avatar
wilhelm86
Default valve stem seal ...
Good afternoon,
I want to change my valve stem seals.
BUT.. I don't want to remove the cilinder heads !
How should I work... can someone send me some instructions?
After this is done, how do I set the valves?
And what sort of seals should I buy, is there a new type or can I use the original GM seals?
Hope that I receive some good help from the guys in the USA ;-)
Waiting for your answer,
Vette Greetings,
Wilhelm
Old Jul 11, 2002 | 02:26 PM
Slow LX's Avatar
Slow LX
Default Re: valve stem seal ... (wilhelm86)
When I did them (valve stem seals & springs) in my windsor motor I used a piece of rope about 3 feet long and fed it through the spark plug hole. Or you can use compressed air to hold the valves up. You do not want to drop one of the valves in the cylinder! :boxing
Old Jul 11, 2002 | 02:27 PM
scorp508's Avatar
scorp508
Also moving whatever cylinder you are working on to TDC will help stop them from dropping in.
Old Jul 11, 2002 | 02:28 PM
Arisa's Avatar
Arisa
I assume you want to change them because the are leaking ???
If so...
You don't need to remove the heads, but you do have to break down the spring assembly. *If* I remember correctly someone on here said you could run each cylinder up to full compression one at the time & do them that way, but I would check on that to make sure I heard/remember right.
I got factory seals for like $1.25 each (in US dollars).
I'm not going to touch the setting of the valves. I'll leave that to the other on the group.
Neal
To valve stem seal ...
