Side Lamp Electrical Issues
Old Jan 12, 2014 | 04:52 PM
keatvette's Avatar
keatvette
Default Side Lamp Electrical Issues
Hello guys. I have a 1991 and my front side marker lights went out. At first it seemed like it was just the bulb but the terminals were corroded and when I went to install new one there is no power. Any suggestions this is really annoying.
Old Jan 12, 2014 | 05:37 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Just to rule out the simple stuff first:
They should only come on when the headlights are on, and that side's turn signal is activated.
See my clarification in post #4 below.
Old Jan 12, 2014 | 05:45 PM
keatvette's Avatar
keatvette
I always tried them with only the parking lights on. That would make sense now. Which in turn I feel like an idiot but if that's the case I will def let you know. Let me try it.
Old Jan 12, 2014 | 06:14 PM
RollaMo-LT4
I think I gave you bad advice above.
The amber marker lights will come on with just the parking lights or headlights on.
The white side marker light will come on with the parking lights or headlights on, and the turn signal activated for that side.
Old Jan 12, 2014 | 06:46 PM
keatvette's Avatar
keatvette
OK that's what I thought . You have any ideas besides cutting into another wire? I really don't want to do that but I need to fix it because the car has to be inspected. Someone suggested a bad ground but the other lights wouldn't come on if that's the case.
Old Jan 13, 2014 | 08:15 PM
keatvette's Avatar
keatvette
I even checked the fuse and its good.
To Side Lamp Electrical Issues
