Z51 experts
Anyways I just wanted to ask if the brakes are the same for a 86 z51. From what I can tell the only 86 z51 differance is gear, sway bars, shocks, springs, wheels, power rack, radiator. Wheels I was gonna sell anyways, but now the rack and front sway bar might be worth taking the time to sell. The rad, gear and stiffer springs I can work with.
Oh and what is the speedometer adapter & key deletes codes all about?
The Z51 included
B4P Radiator boost fan
FG3 Delco-Bilstein shocks
KC4 Engine oil cooler
V01 Heavy duty radiator
9.5" Wheels
HD suspension (see chart at http://corvetteactioncenter.com/tech/c4/susp_chart.html )
Fast ratio steering.
If it was a 4+3, it also got the .67 ratio overdrive (instead of the .59 ratio)
I am not sure which gear was used, but the codes are below.
G44 - Rear axle 3.07 ratio
G87 - Ring gear 8.50 inch
G92 - Rear axle performance ratio
GH0 - Rear axle 3.54 ratio
GM1 - Rear axle 2.59 ratio
GM3 - Rear axle 3.45 ratio
GT7 - Rear axle 3.33 ratio
GU2 - Rear axle 2.73 ratio
GW4 - Rear axle 3.31 ratio
HE3 - Rear axle 3.07 ratio
Your '86 likely had a D3X if it was a "domestic" build. If it's NOT D3X what is it? The delete should have been E?C or maybe E?Z. I haven't looked at an early SPID label in quite some time but those should explain the D's and E's you had questions about. Any others you're unsure of?
