1984 under dash vacuum line?
Old Jan 14, 2014 | 11:04 PM
frankinvett84's Avatar
frankinvett84
Default 1984 under dash vacuum line?
I found a skinny ,black ,hard ,plastic "line" on passenger side under dash, Its not hooked up to anything .upper dash is mostly still apart (interior restore) So I dont want to start engine to see if it draws vacuum .Can anyone tell me what it is ? Thanks
Old Jan 15, 2014 | 12:04 AM
DanielRicany's Avatar
DanielRicany
You have a vacuum supply line that comes in from the firewall. This goes into the HVAC unit. It goes too two areas on the unit, it has a T connector that splices it off to the vacuum harness for the vent door controls, and another one to the heater control valve controls. When you turn the heat on, the heater control valve linkage is fully extended. When you turn the setting to cold, the linkage becomes retracted. Vacuum goes to the heater control valve when on the cold temperature setting. I just went through this today with my 85.
Old Jan 15, 2014 | 05:48 PM
frankinvett84
thanks. I needed that Hope I can get it all back together
Old Oct 27, 2019 | 06:34 PM
djmc52's Avatar
djmc52
Default Same black hose on mine
digging up an old thread but did you find where that black plastic line went under your dash? I have the same one leading nowhere on my 84.
Old Jul 10, 2021 | 06:47 PM
Valience's Avatar
Valience
2nd Gear
Default 96 corvette not blowing air from front vent fix!!!!
Hey guys! I have been fighting this problem for a couple years now! My A/C would blow from top and bottom vents but not from mids. I took apart the passenger side dash and there’s a black vacuum wire that has a yellow/orange nipple connector. THIS WAS THE PROBLEM. The vacuum line was rubbed thru!! I cut a piece off re used the old connector and some glue, plugged it in and VOILA! Air from front vents!
To 1984 under dash vacuum line?
