Is anyone using the ZZ409 cam?
Old Mar 23, 2005 | 06:17 PM
88BlackZ-51's Avatar
88BlackZ-51
i am thinking of running it with a TFS/SR/350 combo?
i want more spunk then the 219, any opinions?
Old Mar 23, 2005 | 06:50 PM
ralph's Avatar
ralph
That cam seems like a good match for both combos described above. In fact, i was considering it as an upgrade for my 350. However, i know of a couple of combos using it, and none run very strong. I honestly don't think it has anything to do with the cam...but i've never seen one run strong. Hopefully someone will chime in set the record straight.
Old Mar 23, 2005 | 06:55 PM
88BlackZ-51
yeah ralph, i just want something with a bit more grunt. i am still new to cams etc.....but from what i heard, more duration is more power.
not many guys use the ZZ409, but on paper it does make sense that it will make more power then the 219 with my intended mods.
yes i am ****, i just dont want to fall short of my goals, and if a ZZ409 will give me more push then a 219, then so be it.....
Old Mar 23, 2005 | 07:19 PM
cv67's Avatar
cv67
St. Jude Donor '05
IMHO, you wont be able to see a lot of difference powerwise in cams unless you jump 8-10 degrees +-@.050 minimum. I'm betting that the hp/tq. numbers in general with like components on most L98 "street cams" run pretty much alike. .02
Old Mar 23, 2005 | 08:17 PM
Mad-Mic's Avatar
Mad-Mic
i got this roller cam and a 224/230 .510/.525 on 1.5 rr's thats in my 388 now. i will most likely go with the ZZ409 cam.
will be doing the install in may. i'll keep ya posted
Old Mar 23, 2005 | 09:00 PM
ralph's Avatar
ralph
Bigger isn't always better.......especially when it comes to cams in a street driven car.
Old Mar 23, 2005 | 10:40 PM
zelement's Avatar
zelement
Very well put...I agree 10000%
Old Mar 23, 2005 | 11:12 PM
88BlackZ-51
so do u guys think the ZZ409 will work well with my application or stick with the 219?
Old Mar 23, 2005 | 11:14 PM
88BlackZ-51
are u saying the ZZ409 is too big?
Old Mar 24, 2005 | 09:52 AM
ralph's Avatar
ralph
The 219 is a proven cam with the SR. I've seen that cam work well in 350s all the way up to 420s. The ZZ409 looks like the next logical step up, but it's probably not going to make much of a difference in performance and it will be a little more radical (idle, emissions, etc). It depends how much you want to push the envelope. I dont necessarily think it's too big, especially if you're trying to squeeze everything you can outa the combo, but there will be some trade-offs. Like i said above, i was considering it as an upgrade for my 350 combo, but i was willing to live with the trade-offs in the name of performance. We are only talking about 5-6 deg in duration, so any differences will be relatively small in the grand scheme of things. So agian, it depends on how far you want to push. The 219 will give you a noticable lope and mine idled somewhat rich due to the overlap. The ZZ409 will push that a little further and if you're willing to live with it.....go for it. You might consider adding a 1/2 point to the CR if you go that route too. Good luck.
Old Mar 24, 2005 | 10:10 AM
mos90's Avatar
mos90
im in the process of swapping cam out my zz409 for a zz-x cam. i do drive my car on the street but only about 2500 miles. the zz-x is big for a street 350 ci. but i want to make the most hp i can and not concered about low end loss or idle quality. it will still make in the area of 14 in of vacuum at idle. zz409 made 16.
to get back to the subject. i had cam zz409 cam in my ported tpi setup, only for 500 miles, but it ran strong and i dynoed at 345 rwhp.
and the idle was very mild for a cam that size.
i am also running close to 11/1 comp ratio.
good luck with your choice...
Old Mar 24, 2005 | 11:20 AM
LPDesRoche's Avatar
LPDesRoche
The 219 cam is the way to go with a SR motor. If you are looking for more grunt have your heads ported and your SR ported as well. I think you will be sorry if you stray from the 219. My opinion is based on my previous cars and cars that I have helped build. You can't beat the 219, SR, good headed combo.
Old Mar 24, 2005 | 11:37 AM
88BlackZ-51
o.k. thanks i am aiming for 10:1 CR anyways, I will have to shave the heads a bit anyways because they are 62CC, May shave them down to 58CC and use a thinner gasket, or just shave them down even less and use a stock gasket. i believe my CR stock is 9.5:1, so another 0.5 shouldnt be too diffucult to gain.
Old Mar 24, 2005 | 11:39 AM
88BlackZ-51
i have not decided one or the other, but i have decided on the SR, and my TFS heads that flowed 260 cfm at .550 lift.
Old Mar 24, 2005 | 12:21 PM
Mad-Mic's Avatar
Mad-Mic
i don't know if the 219 cam is the best for the SR just because LPE says so i will say this though.... 383 stroker, AFR 195 heads, ZZ409 cam, 3500 stall, 3.07 D36, on a stock tune pulls 11.7's at 119 mph.
i think that combo works good. BTW this is my friends 85 vette and i think it still has some left in it with a good tune.
Old Mar 24, 2005 | 12:28 PM
88BlackZ-51
i will prob be going with the 219, looking at scorp's dyno # with 113 heads he got 390/445 without a tune. those are good # man, and i have better flowing heads that you would think are worth at least another 15 chp on top of that, and i am getting her dyno tuned.
Old Mar 24, 2005 | 12:35 PM
Mad-Mic's Avatar
Mad-Mic
which ever cam you go with i don't think you'll be disapointed
Old Mar 24, 2005 | 12:47 PM
88BlackZ-51
thanks man, just want to meet my power goals and run the 1/4 in around the 12.2-12.5 range at 112-114 MPH.
To Is anyone using the ZZ409 cam?
