X-RAM Installation...
Old Jul 12, 2002 | 12:00 AM
IceDigger's Avatar
IceDigger
Default X-RAM Installation...
Should be finished friday! Also added a 85 fuel pump replacing the stock 84 one.
Weeeeee!
Can't wait for this thing! Too bad I can't afford to dyno it after installation costs :(
Any ideas to the performance gains? HP/Torque ranges?
Old Jul 12, 2002 | 01:32 AM
vettl83's Avatar
vettl83
Default Re: X-RAM Installation... (IceDigger)
Check with the guys on the Cross Fire forum they know all the ins and outs of the X-Ram mod. 84 CF 91 ZR-1 :seeya
Old Jul 12, 2002 | 02:32 AM
nsimmons's Avatar
nsimmons
Default Re: X-RAM Installation... (vettl83)
Finally found someone to install it?
You should gain an honest 20-25hp. It will be noticible in the upper rpm, most important the hp wont fall off as quickly so you'll gain a few hundred usable rpm. The fuel pump will also richen up your top end a bit.
Remeber this thing isnt a magic bullet to make the crossfire fast, it will set you up with a good foundation for future mods.
Ive got my car tweaked pretty well, and with the recent deletion of my mufflers 2 days ago,
i'd put it up against any early stock tpi, and would expect to win. I went for a boot yesterday, and was quite suprised when the car went sideways a little on the 2nd gear shift, and pulled good to 4800.
Once i get my other mods done, i expect to be able to hold my own with an lt1 for the first 1/8 mile. Thats good enough for me.
Old Jul 12, 2002 | 10:18 AM
IceDigger's Avatar
IceDigger
Default Re: X-RAM Installation... (nsimmons)
nsimmons, how did you get a ram air in your car? I thought that was just for later model vettes and not for the 84?
Old Jul 12, 2002 | 12:14 PM
kenfusion's Avatar
kenfusion
Weeeeee!
IceDigger,
Good morning, I will have my "after" dyno charts in a few weeks. Sense my last dyno run I've installed the X-Ram, 1.6 roller rockers and a new exhaust.
:cheers:
Old Jul 12, 2002 | 03:47 PM
nsimmons's Avatar
nsimmons
Default Re: X-RAM Installation... (kenfusion)
ice, you just have to cut a hole in the fan shroud and seal it with some weather stripping, so it lines up with the ducting hole in the hood.
Old Jul 12, 2002 | 04:51 PM
kenfusion's Avatar
kenfusion
Nick,
Could you post or send us a pic on this. I've considered doing somthing similar as well.
thanks,
Ken
Old Jul 12, 2002 | 06:14 PM
IceDigger's Avatar
IceDigger
Sounds easy enough. Have you noticed much difference with the ram air on?
Old Jul 12, 2002 | 06:19 PM
flyinace2000's Avatar
flyinace2000
St. Jude Contributor
Alson interested in the Ram Air mod. Lets see those pics!
Will
Old Jul 12, 2002 | 07:43 PM
nsimmons's Avatar
nsimmons
Default Re: X-RAM Installation... (flyinace2000)
a little bit of an improvement, on the topend. Better throttle response..especially in cold weather
Old Jul 12, 2002 | 07:57 PM
Nitro Junkie's Avatar
Nitro Junkie
Join the Crossfire Forum. Read all of the tech articles. Do some of them.
http://www.crossfire.homeip.net:81/cftest/
Your car will get faster. See my sig.
To X-RAM Installation...
