cylinder one and five not working
I have two comments:
1) Did you pull the spark plug(s) on 1/5 immediately after cranking/running? If so, were they wet? If they were wet, that would indicate fuel is being sprayed in the cylinder.
2) I think you should do a proper spark test. Using the "spark plug" method is not accurate. There is a tool specifically made for this that you adjust to the desired gap and see if the ignition system is strong enough to produce the spark to overcome it. The tool looks like this:
http://www.autozone.com/autozone/acc...ier=10257_0_0_
I don't know how easy that is for you to get in your country.
I realize that you replaced the distributor parts last year, but just because they are new doesn't mean that they are functioning properly. There have been many cases of bad parts out of the box that work marginally but not like they are supposed to. If it were my car, I'd be looking at the ignition system very hard.
Good luck.
Simple test, take a pop bottle or water bottle and put some water in it. Drill a hole in the cap 1/8" or so, w/e makes it easy for you too squirt some water where you want it. Warm up the engine and squirt the individual header pipes. If that cylinder is burning good it should burn the water off fast. Good simple way to spot a dead cylinder.
they all should be working, if you have compression, fuel, spark. if a spark plug is fouled -meaning oily, black - then we don't really have spark. we, the readers, have no idea if the plugs are the correct heat range, or if they were new before the latest tests.
for example, the plug used in the video would probably not fire in the engine, with the weak spark.
to know the engine reaction to disconnecting plug wires or injectors, let someone watch the tach as you do it. try that on a good cylinder as well as 1 and 5.
I would verify some simple tests, with two new plugs of the correct heat range and gap, in 1 and 5, to prove that the cylinders are not firing -meaning dead- and eliminate that question.
one thing occurred to me. I don't thing it will be very save to do. but if I had the fuel rail out. I can try to start the car . for a couple of seconds. and see for my self the injector spraying the damn fuel.
Good luck.
regarding the spark plug tester. if I can find it here I will try to get it. but I give you no guaranties
first part you are telling me to measure the resistance of the spark plug wire. I can understand that ok
but the next part is confusing. voltmeter to #1 at distributor and the other end to #5 wire at the plug. don't getting can you explain a little more
But I think that is because #5 exhaust is super close to number #3 making number #5 getting hot also
I get two different image. one that say the dist. rotor rotation is counter clock wise the other say clock wise.
I have always assume that the proper way for my car is clock wise rotor rotation
please let me know if Iam correct..
"I would verify some simple tests, with two new plugs of the correct heat range and gap, in 1 and 5, to prove that the cylinders are not firing -meaning dead- and eliminate that question. "
my educated guess is that #5 was hot because it was firing. if there was any heat in #1, it was firing also. why didn't you post this info before now?
none of your tests so far prove anything -because you didn't verify that the plugs in those cylinders were not basura, garbage.
IF you want to prove it, use the crayon, or lipstick, see if you get heat from the cylinders -with two new plugs, starting with a cold manifold.
as I said in my first post, it does not make mechanical sense that the two cylinders are dead, when they have compression, fuel, spark.
ok I will use the crayon at first chance. will try to get a new plug for testing.
here is the video water test on exhaust
[IMG]
[/IMG]
so is imposible to has change the injectors and check them on the lab. ultra sonic cleaning and spray test. they all come out ok. and number 1 & 5 cylinder still dead. so is not the injectors Iam going to rule that out as this moment.
but I will do it just for peace of mine.
I know it been son time since my last post.
Today i did something i think i will never do.
I sent the vette to a mechanic.
Now i have to wait. And see what he say. He took the car to work specificaly on the number 1 and 5 cylinder. And find out wha is going on.
I will keep you all posted
