Need help 94 electrical
Old Jan 19, 2014 | 04:26 PM
73stang's Avatar
73stang
8th Gear
Default Need help 94 electrical
I have a problem with my 94 convertible when I turn off the car and open the door the radio will not shut off and inside lights won't come on I think it is a ground issue it also sometimes while driving the passenger light will be on but not bright really dim but does anyone know what ground or what might be wrong please help Also if anyone has a master cylinder reservoir they would sell it is the one with the feeder nipple on drivers side of car thank you
Old Jan 19, 2014 | 04:59 PM
Kevova's Avatar
Kevova
Retained Accessory Power (RAP) and courtesy lights should relate to door jam switches or input. Does opening passenger door change anything? Dim headlamp - check connections at lamp. You should also check for CCM codes
Old Jan 19, 2014 | 05:08 PM
73stang's Avatar
73stang
8th Gear
You can open both doors and still same result if I turn the key off and on or try and start the car it will shut off sometimes
To Need help 94 electrical
