95 OBD l or OBD ll
Old Jul 12, 2002 | 01:22 PM
Kdrhpe's Avatar
Kdrhpe
Default 95 OBD l or OBD ll
Just wondering if the 95 LT1's are OBD l or ll
Old Jul 12, 2002 | 01:27 PM
scorp508's Avatar
scorp508
Default Re: 95 OBD l or OBD ll (Kdrhpe)
1, I, i, a, Numero Uno
Old Jul 12, 2002 | 01:35 PM
ZylaRace's Avatar
ZylaRace
Default Re: 95 OBD l or OBD ll (scorp508)
The 95 Vette version is an ODBII hybrid. Take a look at the diagnostic connector. It is described as an ODB1 system w/ an ODB11 connector. ODB1 has a 12 pin connector, ODBII has a 16 pin connector.
Yes, it is confusing.
Old Jul 12, 2002 | 02:00 PM
lite blue's Avatar
lite blue
St. Jude Donor '12
Default Re: 95 OBD l or OBD ll (ZylaRace)
95 was a transition year. They were full OBD II in '96.
Old Jul 12, 2002 | 02:12 PM
RangerZR-1's Avatar
RangerZR-1
Cruise-In III Veteran
OBD I with the OBD II plug and 1 extra O-2 sensor behind the right cat
Old Jul 12, 2002 | 09:40 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
The 95 vette was by default an OBD1 system. Most of the 95s I've seen have OBD2 ALDL connectors for the OBD1 system. As was mentioned, 1995 was a transition year so some late 95s do have fully OBD2 compliant systems (and OBD2 connectors naturally). The best way to know for sure on a 95 is to check for the emmissions sticker under the hood. It will tell you which OBD system is installed on that particular vette.
To 95 OBD l or OBD ll
