1985 Corvette backfiring at 3k - 4k RPM
Hello guys, I have a 1985 Corvette with a Mini Ram, Flat tappet ZZ409 cam, Hedman Longtube 1 5/8" headers, 58 MM throttle body, Cat Delete, AIR Delete, EGR Delete, Dynomax Ultra Flo mufflers, Timing set at 10* BTDC, Descreened MAF sensor, air filter lid cut, K&N Air filter, MSD 8.5mm ignition wires, MSD HEI coil, Heated O2 sensor conversion, AFR Gauge w/ Wideband O2 sensor, 3.75 gears, Speedometer calibrator, Throttle body coolant bypass, G2 adapter and a 27SF512 chip.
When I raise the idle in neutral to 3k - 4k RPMs, if I open the door and stick my head out I can hear little pops in the exhaust. At this moment my AFR gauge is reporting 14.7:1 ish at 3k - 4k RPMs.
Does anyone have any ideas as to what is going on? Thank you!
Could have a Cam lobe going down or collapsed Lifter or lifters.
They Aren't Like Loud Backfires, I Know What The Actual Backfires Sound Like Because I've Been tuning Them Away. They Are Like rumble Backfires. Its Hard To Explain.
What's your timing at those rpms with no load? You could have too much advance. More importantly, how does it run at full throttle?
Here is my timing table. My base timing is set at 10* BTDC, and my Initial Spark Advance in the tune is set at 9.84*.
