1986 Vert Running rough -- All fixed now
Old Jan 25, 2014 | 04:35 PM
3D-Aircrew's Avatar
3D-Aircrew
Default 1986 Vert Running rough -- All fixed now
My car started running rough with a noticeable lack of power, mileage dropped to 12.5 MPG.
Decided to do a minor tuneup -- plugs and wires ... I found one wire burned and cracked and likely shorting to the manifold ... and the plugs all had that grim line on the porcelain. It's been a while so I changed them.
After the job was done I started it up and it did sound better but still a little rough. So I got some carb cleaner and gave the MAF a good cleaning. Started it up again and there was my nice motor back humming like a charm. Stoked that it only cost me a set of platinum plugs, wires and a little cleaner.
I was worried that the cats were clogged. Put that job off for when I put an exhaust system in.
Old Jan 26, 2014 | 12:55 AM
Cliff Harris's Avatar
Cliff Harris
It's possible your MAF burnoff relay is bad and not doing the burnoff function correctly. Mine slowly ran worse over time when my relay was bad.
Old Jan 26, 2014 | 09:38 AM
hcbph's Avatar
hcbph
Default Maf
Good to hear it's now working.
I thought you weren't supposed to use carb cleaner on a maf as it could screw something up. Don't know if you were lucky or my info was incorrect.
Old Jan 26, 2014 | 03:45 PM
3D-Aircrew's Avatar
3D-Aircrew
Default Think it's OK --- I'll watch for the burnoff relay issue.
I've used starting fluid many times before into the MAF so I figured carb cleaner would be OK.
If my car starts to go downhill in performance and especially if it sets MAF codes I'll look at the burn-off relay.
Thanks for the advice
To 1986 Vert Running rough -- All fixed now
