Will front spring sag or sack over time?
Old Jan 25, 2014 | 05:10 PM
Zephyr man's Avatar
Zephyr man
Cruising
Default Will front spring sag or sack over time?
Yes or no? Ask this before with several other questions. Never got an answer.to this one. Thanks.
Old Jan 25, 2014 | 05:21 PM
DanielRicany's Avatar
DanielRicany
I would imagine so. Coil springs do.
Old Jan 25, 2014 | 05:49 PM
eatmydst1234's Avatar
eatmydst1234
What exactly does a cool spring have to do with a C4 corvette?
Yes both front and rear leaf springs can sag. They will also start to splinter on some occasions.
Old Jan 25, 2014 | 07:16 PM
WVZR-1's Avatar
WVZR-1
If it's NOT suffering from any delamination then I'm going to say NO or if it does it would be minimal and not anything that you can see and it would require substantial to measure it. Delamination or a failure of the spring generally results in what appears to be a "splintering" on the edges cross-wise in the car. I don't recall ever seeing one that splintered center to the outer edges (width of spring)where the edges weren't splintered and showing the delamination.
A failure like this would be catastrophic generally and result in one side or the other way out of spec.
Old Jan 25, 2014 | 07:32 PM
DanielRicany
Because Corvettes use mono leaf springs instead of coil springs to suspend the car.
Old Jan 26, 2014 | 01:18 PM
eatmydst1234
Your quote said coil springs springs sag, a C4 corvette doesn't have coil springs. Irrelevant information.
Wv summed it up very well.
Old Jan 26, 2014 | 06:50 PM
Zephyr man's Avatar
Zephyr man
Cruising
Not the answer I was hoping for, but now I know. Thanks guys!
Old Jan 26, 2014 | 10:37 PM
93Rubie's Avatar
93Rubie
How about a factual answer. NO, they WILL not sag. Unless they completely fail, if anything, fiberglass leaf springs don't really wear out. Typical, steel spring has fatigue or even failure at 200,000 full cycles. GM wore out the test equipment testing the fiberglass springs. 2 Millon+ cycles and they gave up. The Z07 springs under my car, as I was told-they are off another Corvette, have 236K on them, I put another 3K on them so far. They don't sag a bit. Perfect as day one. Don't believe me, believe Dave McLellan its from his book.
Old Jan 26, 2014 | 11:25 PM
eatmydst1234
it would seem I am wrong. I think i may have a issue with my car then. I'm wondering if my Z07 has been lowered in the front as it sits a bit low.
Old Jan 27, 2014 | 08:04 PM
jsinga's Avatar
jsinga
I haven't seen a difference in my 87. I've owned it since 1994.
A friends C5 had the front spring splinter.
JS
Old Jan 27, 2014 | 08:52 PM
RUU's Avatar
RUU
Mine also seems too low in the front, infact the driver's side seems to sit an inch lower than the passenger side. There is no splintering visible and the front spring does not appear to have been modified to lower the car. The rear spring still had the factory bolts & bushings when I bought the car.
Old Jan 28, 2014 | 02:02 PM
WVZR-1's Avatar
WVZR-1
Where are you measuring? There are specific points where the car needs measured to confirm dimensionally that is within specs. It is NOT measured at the hood edges or the quarter edges at the wheel openings.
To Will front spring sag or sack over time?
