LT1 Spark Plug Wire Looms / Retainers
Old Jan 26, 2014 | 03:39 PM
TorchTarga94's Avatar
TorchTarga94
Default LT1 Spark Plug Wire Looms / Retainers
Do any of you guys have a good source for the plastic spark plug wire clips? I have found a few part numbers but not sure if they are correct. I believe part # 12132272 is the 4 wire clip, but not sure. I have the metal brackets that attach to the heads, but the plastic clips have broken (this is what I need). I know Eckler's and MAM sells a kit but I have heard they are not the correct clips and are junk. I am using the zip-tie trick right now which doesn't look bad.
However, I think the factory retainers still look the best. Unless someone else has come up with a better solution to hold 8mm wires?
Old Jan 26, 2014 | 10:38 PM
93Rubie's Avatar
93Rubie
I put some ones from Ecklers on a buddies 94, they are fine, fit and function perfectly.
Old Jan 27, 2014 | 12:47 AM
94flavette's Avatar
94flavette
I bought some Moroso looms from Summit. Fairly pleased with them.
Old Jan 27, 2014 | 10:25 PM
csthews's Avatar
csthews
The clips I bought from Ecklers were wrong. I then bought a used set from vette2vette. Looks and works fine.
Old Jan 28, 2014 | 09:55 AM
Protour63's Avatar
Protour63
I just bought some from Corvette Central for my '85 and they are identical to the AC Delco ones I used to get from the dealer. Think they've been discontinued from dealer now. Same dealer price from CC but quality is good.
Old Jan 28, 2014 | 07:13 PM
TorchTarga94
Appreciate it guys. I keep getting mixed reviews about the kits from ecklers and MAM. Ill check out corvette central.
94flavette- would you happen to have a link or pic of them on your car?
Old Jan 28, 2014 | 10:30 PM
l88rocket's Avatar
l88rocket
8.5 wires wont fit a stock retainer clip
Old Jan 29, 2014 | 12:03 AM
94flavette's Avatar
94flavette
Clicky
Old Jan 29, 2014 | 08:35 AM
TorchTarga94
l88rocket- I don't have 8.5mm wires. I have Taylor Spiro pro 8mm's. The picture in my OP is just to show what I am using for looms.
Thanks 94FLAvette
To LT1 Spark Plug Wire Looms / Retainers
