Rear window drain kit
Old Jan 27, 2014 | 07:52 PM
hdrydr1051's Avatar
hdrydr1051
Default Rear window drain kit
Has anyone installed a rear window drain kit and are they needed. I do notice water in the corners after washing and usually I will use paper towels and dry it out. Drilling holes required to install. 1985 C4.
Old Jan 27, 2014 | 10:40 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Yep
Old Jan 28, 2014 | 01:13 AM
Cliff Harris's Avatar
Cliff Harris
I have installed one of those drain kits. I like it a lot.
You have to be careful with the drilling. As I recall, I drilled through THREE layers to get all the way through. There was a thread here a while back where the poster didn't drill far enough and his rear compartment filled up with water (not good for the anti lock brake system).
Old Jan 28, 2014 | 01:28 PM
corvettenorway's Avatar
corvettenorway
Old Jan 28, 2014 | 01:33 PM
69mako's Avatar
69mako
Just drop $6.00 for a turkey baster...its cheaper and no drilling
Old Jan 28, 2014 | 01:58 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default water
I just take my 1985 and 1996 for a drive after washing. Check water accumulation in the hood latches.
Old Jan 28, 2014 | 05:13 PM
Nick DL's Avatar
Nick DL
Depending on mood, I either just use my leaf blower or air compressor to blow the water out.
Old Jan 29, 2014 | 09:31 AM
Steve59's Avatar
Steve59
I use a baby's snot bulb...keep it in the console
Old Jan 29, 2014 | 09:33 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I use a silicon rubber ear syringe. Keep it with the car care stuff; fewer questions to answer that way.
Old Jan 30, 2014 | 01:34 AM
Hot Rod Roy's Avatar
Hot Rod Roy
There are drainage openings in the bottom of the hood latch brackets. If you have any water in your bracket pockets, remove the hood latch plates and clean out the openings! While you've got the latch plates off, give the latch pivots a grease job. Removing the latch plates will not affect the alignment of the latches.
Old Jan 30, 2014 | 07:47 AM
WW7's Avatar
WW7
You guys can use your turkey basters, baby snot bulbs, or anything else you might think of, but the problem is still going to exist... The only way to fix it correctly ( like it should have been done at the factory) is to man up, and drill some holes in the car...... If you want to make sure you get it right, just pull the carpet down on the inside of the car where the holes will be drilled. This will allow you to see the drill bit penetrate to make sure your not hitting any wires. Drill the holes, insert the tubes with the included sealer on them, let it dry, and never ever have to worry about water in the back window again...Believe me, putting 2 more holes in the car body isn't going to hurt, and it's nice not to ever have to worry with this "Factory Defect" again.......WW
Old Jan 31, 2014 | 04:01 AM
Cliff Harris
with WW7.
You can't see the drain anyway -- it's hidden by the hatch weatherstrip.
Why deal with the water when a simple mod will banish it forever? I did this mod about 10 years ago, and I'm glad I did.
To Rear window drain kit
