Hard time putting 6-spd into gear when cold...
Old Jul 12, 2002 | 07:50 PM
NE14SIN's Avatar
NE14SIN
Default Hard time putting 6-spd into gear when cold...
Anyone know if this problem might be because of a low fluid condition?
Old Jul 12, 2002 | 08:05 PM
silver & red CE's Avatar
silver & red CE
Default Re: Hard time putting 6-spd into gear when cold... (NE14SIN)
I had this problem, since my Vette was under warrenty I took it to the dealer. He changed the lube out and put in fresh factory lube. No difference. Two years later I replaced the factory stuff with the ZF approved Castrol 10W-60 (the stuff from BMW). All I can say is WOW, much better. I've heard RedLine is good too, I just prefer to use ZF approved lube.
IMHO, it's also a good idea to bleed the clutch once a year, that can also cause hard shifting.
Eric
Old Jul 12, 2002 | 08:13 PM
John Row's Avatar
John Row
I had this happen to a 65 GTO about a hundred years ago. Change fluid a couple of times and viola! Easy shifting.
Like chicken soup. It couldn't hurt.
Old Jul 12, 2002 | 08:16 PM
NE14SIN's Avatar
NE14SIN
Default Re: Hard time putting 6-spd into gear when cold... (John Row)
A hundred years ago...kinda gives new meaning to the term M-22 Rock crusher!!!
Old Jul 12, 2002 | 09:26 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I just let the car warm up. We had this problem on our tractors in the winter. We had to remove the shifter and actually stir up the tranny oil to loosen it up just so we could getthe damn thing started!
Old Jul 13, 2002 | 09:47 AM
Vettman 1's Avatar
Vettman 1
I was having a similar problem, also 2nd to 3rd shift was "notchy". Turned out to be a leaky slave or master cylinder. Replacing them both solved the problem. :D
To Hard time putting 6-spd into gear when cold...
