Clunking from the rear?
Old Jan 28, 2014 | 11:57 PM
DanielRicany's Avatar
DanielRicany
Default Clunking from the rear?
Hey guys, 1985 Corvette, clunks in the rear. It doesn't seem to be consistent, if I can remember correctly it happens more when going over a bumpy road.
I was thinking sway bar links, my friend suggested U joints. I don't think it's U joints because it happens when I go over bumps.
What do you guys think? How do I test swap bar links with bushings?
Thanks!
Old Jan 29, 2014 | 06:18 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
Best thing to do is jack it up and look at your bushings and check for play, if its your sway bar link bushings or any other bushings you should see the rubber coming apart or dried rotted bushings. Also check your wheels for any play while it is jacked up.
Old Jan 29, 2014 | 10:26 AM
корвет's Avatar
корвет
Also check your tie rod ends, c-beam bolts and even your hub assembly.
Old Jan 29, 2014 | 11:13 AM
3D-Aircrew's Avatar
3D-Aircrew
Default Half-shaft Ujoints are part of the suspension
Thanks!
If the needle bearing are missing there can be as much as 1/4" of play in your half shaft which could show up as a clunk ... ask me how I know.
Old Jan 29, 2014 | 11:20 AM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
ok...how do you know?
To Clunking from the rear?
