Roller Rockers?
Old Feb 1, 2014 | 07:52 AM
DanielRicany's Avatar
DanielRicany
Default Roller Rockers?
Hey Guys, I Have A 1985 Corvette, My AFR 195 Heads Are Coming This Week And I Was Wondering If These Roller Rockers Will Work With These Heads? Also, Will They Fit With The Stock 1985 Valve Covers?
Thanks!
http://store.max-redline.com/servlet/-strse-740/Detail
Old Feb 1, 2014 | 08:19 AM
DanielRicany
Actually, I would like to buy these ones instead. The previous site doesn't have such great reviews. I'll spend an extra few dollars for these. Will these work?
http://www.summitracing.com/parts/cc...make/chevrolet
Old Feb 1, 2014 | 09:32 AM
John A. Marker's Avatar
John A. Marker
You can "make" them fit. Things to do:
1) Grind off the drip tab inside the stock covers. Do not try to break them off you will break a hole in the cover
2) Use the tallest gaskets you can find or double up the gaskets by gluing two together with 100% silicone and let the gaskets set at least 24 hours. You will have to get longer bolts for the covers
3) I had a 74211 LPE cam in my ZZ4 with the stock covers. The lift on the exhaust was .534 (from memory). These 1.6 rockers I had just kissed the cover with a single gasket. I solved this problem by wrapping the entire rocker in masking tape and then taking a sanding disk on my grinder, I sanded a 45 degree angle on the push rod end. I sanded this down about 3/16" and it gave me about 1/8" clearance. There was no structural problem with the rockers I used.
Old Feb 1, 2014 | 09:58 AM
WW7's Avatar
WW7
Like mentioned above , (you can make them work), but why not get a good set of roller rockers like Scorpions or Comp cams better rockers.Your getting one of the best heads available , why cheap out on the rockers.The cheaper rockers also tend to have more noise then the better rockers...Make sure the springs will work with whatever you decide to get, also the push rods have to be the proper length.....Instead of working the stock valve covers over to make them work, why not get a set that are made for 1.6 rockers.. I have a set of Proform GM valve covers that are only 1/4" higher then stock and look great on the engine, you can get them in either Krinkled Black or polished aluminum for just a hair over $100.00...This is just my opinon, Im sure some will disagree......WW
Old Feb 1, 2014 | 10:12 AM
c4cruiser's Avatar
c4cruiser
I would also look at Harland Sharp rockers or The Lunati VooDoo rockers. You might want to watch the video which discusses rocker arms. The link is under the pic of the rockers.
As mentioned, you can grind off the tabs on the inside of the valve covers for clearance. And use two gaskets on the covers. You will probably won't be able to use tall valve covers. I assume the valve covers have perimeter bolts rather than center bolt?
It can't hurt to check with AFR to see what rockers they might recommend with their heads. Some roller rockers may not clear the springs that came with aftermarket heads. And some roller rockers won't work with the 87-later centerbolt valve covers.
Old Feb 1, 2014 | 10:23 AM
WW7's Avatar
WW7
As mentioned, you can grind off the tabs on the inside of the valve covers for clearance. And use two gaskets on the covers. You will probably won't be able to use tall valve covers. I assume the valve covers have perimeter bolts rather than center bolt?....
Looking at the Summitracing pictures of the AFR 195cc heads, it looks like they're tapped for either Perimeter or Center bolt valve covers. My Dart heads are the same way....This gives you more of a choice of aftermarket valve covers...WW
Old Feb 1, 2014 | 10:47 AM
cumbercr's Avatar
cumbercr
I use Comp Cam Ultra Gold rockers with AFR 195 heads. The heads work with perimeter or center bolt covers. With stock covers the tabs will definitely need to be ground off. But there's also interference with the inboard wall of the cover. In some cases there's so much interference that the corners of the rockers have to be ground down. Aftermarket covers designed for roller rockers have that wall moved inboard to provide extra clearance.
When I installed my first set of AFRs I found a Summit brand valve cover that was short and was designed for rollers. I think they cost me $75. If you go to an aftermarket cover keep in mind that most tall covers will not clear the wiper motor.
Old Feb 1, 2014 | 11:59 AM
WW7's Avatar
WW7
If he wants to stay with perimeter bolt covers, I believe these may work with the wiper motor on the 85, since they are angled down at the ends... On the later model Corvette's the wiper motor isn't a problem, my 89 has centerbolt proform covers that fit without touching the wiper motor...WW
http://www.summitracing.com/parts/pro-141-108/overview/
Old Feb 1, 2014 | 03:16 PM
DanielRicany
Okay I ordered the Comp Cams roller rockers. I'll modify my current valve covers to make it fit. If it doesn't work, I'll shop around for some that do fit. Thanks!
Old Feb 1, 2014 | 03:20 PM
cumbercr's Avatar
cumbercr
I tried those covers. I thought they would work too. But they interfered with the wiper motor and with the rockers on the inner wall. If you look at the Summit description, they don't mention being compatible with rollers.
Old Feb 1, 2014 | 05:56 PM
captainkawasaki's Avatar
captainkawasaki
I have full body Crane gold rockers and they hit after the drip tabs were ground off. A big fat valve cover gasket (.25" mr. Gasket jobby if memory serves) took care of the rest of the clearance issues.
Old Feb 1, 2014 | 06:13 PM
TBSS/85vette's Avatar
TBSS/85vette
I put 1.5/1.6 PRW stainless rollers on my 1985 last spring and didn't have any problems with fit. I used a Dremel with a cut off wheel to take out the drip tabs on the stock covers. I used a Felpro dry silicone/metal reinforced gasket that was recommended in other threads on here, it's pricey from what I remember but thick and sealed perfectly, not a leak. The only problem I had was the provided polylocks were too tall and would not fit under the cover so I had to buy the short version. It's a great upgrade and you will feel the difference. I also used stock length upgraded pushrods with no problems. This is a video just before the final adjustment and the stock covers went back on. Tap the picture.
Old Feb 2, 2014 | 09:33 AM
DanielRicany
Okay thanks for all the advice guys, but I have a question. I was talking to my friend about what I was doing and he said not to remove the valve cover bafflers. I was reading online about it and people were saying that without it the PCV valve may suck actual oil into the intake.
Does anyone have any more information about this? Thanks!
Old Feb 2, 2014 | 10:07 AM
John A. Marker
We did not tell you to remove the baffles. It is the DRIP TABS which are part of the cast covers that have to be removed so the RR will fit.
IF you are going to use the stock cam in the 85 then the covers will fit with the tabs removed and a stock gasket.
If you have a high lift cam, then you will have to go to a taller gasket and perhaps modify the rocker itself as I suggested. It will depend on the lift of the cam.
Old Feb 2, 2014 | 10:21 AM
DanielRicany
Sorry but I'm not really sure what part is the drip tab. Do you have a picture that you can show me? Thanks!
Old Feb 2, 2014 | 11:22 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I've got the Comp full rollers w/ 1:6 ratio under these. I had to grind a tiny bit of the top fin off the rear to clear the wiper motor. I'd still like to see some pics of your '85, hurry up & get it done so we can see it.
[IMG][/IMG]
Old Feb 2, 2014 | 01:52 PM
383vett's Avatar
383vett
Another vote for Crane Gold rockers.
To Roller Rockers?
Old Feb 2, 2014 | 03:54 PM
John A. Marker
My drip tabs are long gone. Just take off the valve cover and turn it over and look inside. You will see part of the casting on the inside top of the cover that is about 1/8" thick and about 3/4" wide and drops down about 1/2" or so. This is the "tab" we are talking about. There are several under the cover. Don't remember the exact number.
Grind them off with a die grinder or use a Dermal with a small cut off wheel and cut them off.
Old Feb 2, 2014 | 04:12 PM
DanielRicany
After doing some research it appears that my car doesn't even have drip tabs.
Old Feb 2, 2014 | 05:54 PM
cumbercr's Avatar
cumbercr
If it has the stock valve covers it does. Mine did.
