Brake Pressure warning switch
Old Feb 1, 2014 | 12:19 PM
hdrydr1051's Avatar
hdrydr1051
Default Brake Pressure warning switch
Found my brake pressure warning switch disconnected a few weeks back. Reconnected and now the brake warning light on dash stays on. Checked switch to parking brake and was ok. Disconnected switch on master cylinder and light went out. No visible leaks on switch or M/C. Possible bad switch? Found one on Amazon for @$25.00. Also what is correct voltage on switch. Just bought 01/14 and issues are starting to show up.
Old Feb 1, 2014 | 01:05 PM
hooked073's Avatar
hooked073
These switches seldom go bad. My quess is loss of pressure on one side of you brakes and the switch is indicating that. You can try a switch but you are most likely go to have to fiqure out what is going on with the pressure in you brake system
Old Feb 1, 2014 | 01:11 PM
DanielRicany's Avatar
DanielRicany
Okay so the purpose of the brake pressure switch is to alert when there is a difference in pressure from the front system and the rear system. There are a few possibilities.
Bad proportioning valve, bad pressure switch, clogged brake lines, bad master cylinder, electrical problems, etc.
I would say it's probably a bad switch.
This light should only come on when either the parking brake is applied, or when there is an unequal amount of pressure in the brake system, WHEN YOU STEP ON THE BRAKE PEDAL. If it's on all the time, it's more than likely a bad switch.
Sorry for this diagram being sideways. You can print it and look at it straight up.
Old Feb 1, 2014 | 02:57 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Like Daniel said, this switch warns you if there's an imbalance between the front and rear brake line pressures. This may happen when you bleed your brakes, so the previous owner may have had the light come on after he (or she) bled the brakes, but didn't know how to reset the light. That may be why the switch wasn't connected.
1. Leave the switch plugged in.
2. Install a tube onto a front brake caliper bleeder fitting, as you would to bleed the brakes.
3. While a helper steps on the brake pedal, open the bleeder while the helper watches the dash light. He may have to push hard on the pedal. If the light doesn't go out, close the bleeder fitting before releasing the brake pedal.
4. If the light didn't go out, repeat this procedure with a rear caliper.
Old Feb 1, 2014 | 05:58 PM
captainkawasaki's Avatar
captainkawasaki
I had the same problem after replacing the front soft lines this winter. The culprit was a sticking proportioning valve. New master cylinder for me and now its good to go
Old Feb 1, 2014 | 08:08 PM
mxw128's Avatar
mxw128
Youre talking about the white one on the side of the master, right? Mine broke, but was visably separated. They are easy enough to check, it's only an open/closed switch I believe...
Old Feb 2, 2014 | 12:11 AM
MotorCity_87_C4's Avatar
MotorCity_87_C4
My switch was bad, Brake warning lite came on when applying the brakes. Was a 1 minute fix.
Old Feb 2, 2014 | 02:50 AM
Cliff Harris's Avatar
Cliff Harris
Sometimes the shuttle inside the master cylinder gets off center and causes the switch to close and light the BRAKE light. That usually happens when you bleed the brakes and then it gets stuck in the off-center position. My light came on after I bled the brakes recently but it went off the first time I stepped on the brake pedal.
You could try poking something sharp down into the switch opening and see if you can align the shuttle. There is a groove in it that the tip of the switch fits into. The first picture in this post shows what to look for:
http://forums.corvetteforum.com/1585621532-post1.html
Old Feb 2, 2014 | 08:35 AM
HandsomeMike's Avatar
HandsomeMike
My master cylinder went bad and was replaced. The shop didn't bleed the brakes right and the light stayed on all the time. I took it back a few days later and they bled it correctly and got the pressure right and the light went off. The shuttle valve was off center causing the light to come on. You can unscrew the switch (slowly, there is a spring and pin in there) and look in the hole to see if the valve is off center.
Old Feb 2, 2014 | 10:22 AM
mxw128's Avatar
mxw128
I'd bet Cliff and HandsomeMike are right, the switch itself is pretty simple and apart from it maybe breaking off or cracking like mine did, can't really see it going "bad"...
Old Feb 2, 2014 | 04:34 PM
hdrydr1051's Avatar
hdrydr1051
I did exactly that. Removed switch and checked the alignment and reset shuttle. Minor realigning. Reinstalled switch and brake warning light is now off. Will monitor and see if it comes back on and stays on like before. Thanks. Glad this website is available for help and info.
Old Sep 22, 2019 | 09:22 PM
fredalvrez@gmail.com's Avatar
HI Cliff
I realise this is an old post, but I'm having the same issue. Brake light is on when the wire is connected to the master cylinder - on all the time. Sometimes there's a brief moment when it goes off.
I can't view the pictures in that post - they are blocked? - but tonight I took out the switch carefully, and the spring. There's a needle type of thing connected to the switch that comes out, and it goes into a speherical (spelling!) chamber, but I can't see any groove. There's just a small circular opening for the needle to go into. Is it down this hole I can safely poke something very skinny? There's no way a screwdriver is going to get down there.
Cheers for any help.
Fred
To Brake Pressure warning switch
