Codes after removing ECM
Old Feb 5, 2014 | 03:32 PM
Mtn Billy's Avatar
Mtn Billy
Default Codes after removing ECM
Ugh! I had to replace the heater core in my '85 and now I have 12 codes and the Check Engine Lite. Before I pulled everything out I checked to see if there wuz anything that needed to done with the ECM and disconnected the battery. It's a little disconcerting that all this stuff happened. My question is did I miss something and the FSM didn't list have any information. I have a scanner and pulled codes and will work these out. I guess I wanna know wot happened?
Bill
PS. Wuz it the anchovies?
Old Feb 5, 2014 | 04:02 PM
Kevova's Avatar
Kevova
A lot of stuff gets disconnected replacing heater core its possible a multi-wire connector is not fully connected.
Old Feb 5, 2014 | 04:18 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
It may help if you could post what codes.
Old Feb 5, 2014 | 07:45 PM
Mtn Billy's Avatar
Mtn Billy
Codes are
12 diagnostic mode, no dist signal to ECM
13 oxy sensor
14 coolant sensor
22 TPS
25 Spark referance 24x signal (low volt) or MAT or IAT temp high
31 CAM sensor
36 MAF burn off, DIS fault loss of 24x, Ignition sys fault loss of HRP signal
41 CAM sensor, Cylendar select error, Elec Spark Timing open or shorted during running, Ignit sys fault loss of 1x reference pulse signal
42 EST open/shorted
Two I know about deal with the cruise control.
Old Feb 5, 2014 | 07:47 PM
Mtn Billy's Avatar
Mtn Billy
I'll deal with this when it gets above 0*.
I did leave the dash covers and stuff off just in case....
Old Feb 5, 2014 | 08:34 PM
Kevova's Avatar
Kevova
With codes that are set I would double check both connectors are fully seated in ecm and/or for blown fuse first. The codes center with C-D connector which is the longer of the 2.
Old Feb 6, 2014 | 01:28 AM
Cliff Harris's Avatar
Cliff Harris
Originally Posted by Mtn Billy
Codes are
13 oxy sensor
14 coolant sensor
22 TPS
31 CAM sensor
42 EST open/shorted
Those codes are not for an '85. First thing I saw was "CAM sensor", which an '85 doesn't have. All the cruise control functions are done by the dashboard, not the ECM.
You said your car is an '85, but maybe it's a '95?
If not a '95, then you need the correct scanner data template. Reset the ECM and see how that affects the error codes.
Old Feb 7, 2014 | 07:13 PM
Mtn Billy's Avatar
Mtn Billy
Wish it was an 95. Sadly is is an 85. The code numbers correspond with problems, not with what the scanner. Any abnormality could be with the Innova 3140B that returns multiple possibilities. The FSM helps but sometimes its frustratingly painful to work thru it. Guess thats why we have Bud Lite.
I'll try resetting the ECM tomorrow thanks
Old Feb 7, 2014 | 07:58 PM
leesvet's Avatar
leesvet
are you reading the "Flash codes" ?????
and does that correspond to what your scanner says? I bet it don't...
Seeing the list of almost every eng mngt code there is tells me that its communication and not actually problems. Check the ECM harness plugs and IF the flash codes are showing ALL these, which I doubt, (would take a week to display thru that many) I'd drop the ECM and check the prom, and pins in the connectors..
Old Feb 7, 2014 | 08:07 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Ok, so did you remove the ECM? or just the battery? Did you have any grounds off? What were the codes before you started?
Old Feb 8, 2014 | 10:56 AM
Mtn Billy's Avatar
Mtn Billy
The battery was disconnected and the ECM removed. To back up a little the cruise control is code 63.
Old Feb 8, 2014 | 01:24 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
As suggested go back and remove and check all the ECM plugs check the pins very close and reseat. I have found over the years when something messes up after I worked on it, it was something I touched.
Old Feb 8, 2014 | 08:57 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I'm gonna pass on that one........
You really need to disconnect and ensure the ECM connectors are fully seated.
I fought with those blue "combs" that safety the connectors.
After having many long discussions with those combs, they decided they were not necessary and flew out the window.
Haven't had a problem since they flew the coupe....
To Codes after removing ECM
