Smog pump removal?
Old Feb 6, 2014 | 07:57 PM
Adr3nalineJunky's Avatar
Adr3nalineJunky
6th Gear
Default Smog pump removal?
i have an 89 vette and i want to remove the smog pump. i did the same in my 89 iroc and i just had to get a shorter belt, but it seems like its not that simple this time... has anyone done this? what all is needed
Old Feb 6, 2014 | 08:38 PM
floridamale's Avatar
floridamale
Most just get a after market bracket & pulley set up, you can remove all the tubing and connections with out throwing any codes. There are few places to get them.
Here is what I have I was able to use the same belt
With the pump and others things removed the L98 cleans up well, you should also look into doing the water hose by-pass with your throttle body
Here is a link
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
Old Feb 6, 2014 | 10:09 PM
vetteoz's Avatar
vetteoz
Completely different setup on a C4.
You require the idler pulley shown above to prevent the belt rubbing on the PS pulley
Old Feb 9, 2014 | 12:40 PM
ILowNslowI's Avatar
ILowNslowI
Going to do this on mine as well, I'm getting a pulley squeal from the pump but just confirming this does NOT kick on the CEL?
Old Feb 10, 2014 | 10:10 PM
HlhnEast's Avatar
HlhnEast
No codes. I think I ended up with a 1" shorter belt as well. i have no AIR pump and associated piping(front of engine and exhaust manifolds), AIR switches or solenoids, no EGR piping or valve, and did the TB bypass including removal of the IAC water jacket and its amazing how much cleaner the engine bay is. Really easy to change spark plugs, remove valve covers, access sensors and more. Do it all you wont be sorry. No smog in FL!
Old Feb 11, 2014 | 11:21 AM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
I really like the look of those valve covers. Where do you put the oil in?
Old Feb 11, 2014 | 06:23 PM
floridamale
I have holes milled into the top sides oil fill is through PCV opening. Breather to TB is on top passenger side in rear you can see tube running along top of cover
Old Feb 11, 2014 | 10:17 PM
FOURSPEEDVETTE
Very nice.
Old Feb 20, 2014 | 01:39 PM
vettespecial's Avatar
vettespecial
Default Air pump
Installed AIR pump Delete kit on my 90 L98 and reinstalled the original belt
it fit new pully. and tension correct. thats my experiance with it.
Old Feb 20, 2014 | 02:06 PM
vader86's Avatar
vader86
No it doesn't kick the light on. No codes.
To Smog pump removal?
