Water temp always displays "LO" on 87, Sensor Problem or what?
On my 87 my water temp display always shows "LO" on the display. I have never seen an actual numeric value. I noticed my oil temps will show low but only for a short time after I start the vehicle and start driving, then I get a numeric value. So Im assuming the water temp should work the same way. Do I have a bad or possibly disconnected sensor? Where is the sensor located? At what temp is the display suppose to start showing a numeric value instead of "LO"? :confused:
Re: Water temp always displays "LO" on 87, Sensor Problem or what? (js0308)
The sender is in one of the heads and if I remember correctly, it is just opposite of what the manual says. Manual says driver side, so might check the passenger side, between the #6 and 8 cylinders. Good Luck
Location: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
1 Post
Cruise-In II Veteran
Re: Water temp always displays "LO" on 87, Sensor Problem or what? (mash557)
