Results from e-town on LT4 conversion to an A4
We have been testing the car over the past few weeks at Raceway Park, Englishtown, NJ and the results have been remarkable despite the hot weather. We are running et's consistently in 12.6's to 12.7's and in the cooler weather last wednesday went a 12.48.
Other mods include a GM hot cam, 4:10 gears, BFG 315 DR's and a heavy duty radiator with a 160 thermo. Most everything else on the car is stock including the stock exhaust manifolds (it does have Borla mufflers though).
We converted the car primarily because we use it as a drag car, and unfortunately my Dad had a helluva a time driving the 6M consistently (he's not the only one). Plus I got tired of changing worn out clutches every three months ;) .
So if consistentcy was the goal, then the car has far exceeded our expectations. Check out the data below. My Dad took 2nd place in the GM Hi Tech performance race in the AM session on July 14th. He handed the keys to me for the PM session of the Cartek Corvette Challenge, were I lost to REDGAR in the semi's. As John Mackey says, converting to an A4 was "the best thing you could ever do!"
The most amazing thing has been the improvement in the 60' time. With the 6M, an average day would yeild 60' that were anywhere from 1.85 to 2.00. We considered a 1.80 to be VERY good. The A4 rarely has a 60' greater than 1.80.
We will be looking for very low 12's once the weather turns cool. And who knows, maybe next we'll port the heads!
Note: bold entries in the table above are new personal records.
Also some people have asked for some "before" data.
Here's some data from last year. The car was in the same configuration except with the 6M and with a single mass flywheel. I picked a day that had similar weather conditions to this past Saturday.
[Modified by Eric Fischer, 2:04 PM 7/16/2002]
The auto is not faster, just more *consistant* with a driver who isn't good at paddling gears.
I think the car on average will be consistently faster too - i.e. as long as the track cooperates the car will routinely run 12.4's to 12.7's depending on the weather.
The A4 just launches harder and more consistently than a 6M (at least on drag radials). The 6M can be made to be consistent (big tires or slicks, rev limiter for launch, etc), but you still run the risk of missing a shift. Somedays, with the 6M I could launch as high as 5000 RPM without wheelspin. Other days it would spin at 3000 RPM and I would have to slip the clutch to get a decent launch...
