Hi all. 3 months ago I completed my rebuild of my 86. My problem is, I won't go closed loop. Also the car won't stay running without keeping the gas on because it will want to idle below 600 rpm. Sometimes if I cycle the key a couple times, it will idle up at 8 or 9 hundred until it warms up. I have tried 2 o2 sensors, heated o2 sensors, my own ground for the 02 sensor, checked ecm grounds, new ecm, and the stock chip. There's no codes. But the block learn says 15. I know that the car shouldn't even run that rich. It definately is running very rich and puffs black when stepping on it. Fuel pressure is good. I called Ed Wright but he would not even talk with me. Just said my O2 sensor wasn't getting hot enough. My sensor is on the #7 tube on my header. When I read the O2 reading, it's toggling up and down like it's supposed to. The only thing different from some of the combinations I see on here is my camshaft. It has 110 degrees lobe seperation. I don't think this is it. It really feels like a programming problem to me. There are a couple other things I've checked but can't think of them right now. Throw some idea's at me please. I'm finally at a dead end. Keep this thread alive pleeaassee.
I'm sorry my mods don't show for some reason. I have a 52mm throttle body, edelbrock intake, adjustable fuel reg, 12-234-2 comp cam, ceramic hooker headers, flowmaster exhaust, .030 over, keith black flat tops, Ed Wright chip.
Fisrt, your LSA of 110 isn't helping things out much. Besides that point, the cam of 212/218, 0.447/0.454 really isn't too radical for TPI.
I think that with a scanner, your O2 voltage is going to be high...in the 820-850 mV range....and that it is going to stay there. If you got one of the non-custom chips from Ed, there within lies the problem. It is not modded enough for cam changes. That cam makes your engine less volumetrically efficient at low RPMs in exchange for better breathing at high RPMs. You will be rich at the bottom end and if the ECM can't compensate enough, then it just can't. Plus, it can't compensate if you don't go into closed loop as you already know.
If you ask me, I would tell you to lower your fuel pressure. Excess fuel *can* keep the O2 too cool.
And I take it you are noticing that the ECM doesn't go closed loop with a scanner?
So if your O2 sensor is toggling correctly check coolant temp with the scanner. Either being off will keep you out of closed loop.
I Missed that part. I saw using different O2s and figured it wasn't toggling. I would have to agree coolant temp that the ECM is seeing is a prime culprit. Doh.
Re: no way will my car go closed loop (HighHopes85)
Thanks guys, I'll adjust my fuel press. tomorrow. My coolant temp is not the culprit. I purposely removed the fan fuse and let it get good and hot to make sure that wasn't the reason.
They mean the sensor! Scan it and check that the ECM is seeing the correct temp.....
Re: no way will my car go closed loop (ski_dwn_it)
I tried the stock chip. No change. I also tried revving it up for a long time. No change. I performed the O2 test on the tech 1 and it wouldn't complete because it wouldn't go closed loop. I still think it has something to do with programming as well as the block learn reading 15. As mentioned before, I will lower fuel pressure tonight after work. I was thinking a possible leaking injector on #7 but that seems quite coincidental since it wasn't doing it before my project. As well as being on the same cylinder as the o2. Keep the ideas coming and I will keep you posted.
I remeber a while back talking to a Tuner, and they rattled off the condidtions that must be met before you can go closed loop. Hmmm now only if I can remember what they were.
The 110 LSA isn't the problem. I run a big nasty cam on a 110 LSA without any problems. My car idles fine and has never stalled. Hopfully someone will chime in with the conditions.
Almost everything is based on the MAF coming into the engine. LV8 is calculated from it just to mention one.
If the sensor is not reading the correct amount of airflow, all sorts of weird things can occur. I have never heard of no closed loop, but it might have an effect.
Can you get a different one from someone else or better yet to make sure its not a relay or something, put your MAF in there car and see if it goes to closed.
If you can find someone will. You could swap out a bunch of stuff and try it in their car until you have either eliminated everything, or have pulled your hair out.
Man I wish I could help you more. SOund like it the MAF because it should not be stuck in cell 15 all the time. I will find out what governs the cells. I think its the MAF though. I will make sure.
Ref: "How to Tune & Modify Chevy Fuel Injection", by Ben Watson: three things are required for the ECM to enter closed loop mode after startup:
1) the coolant temp must reach a certain temp
2) the O2 sensor must reach operating temp
3) a preset time must have elapsed
So, the ECM is seeing a problem in one of those areas or the ECM is faulty.
I just thought of something after I hit the send button.
You may have tried this, but I did not recall reading it anywhere in the posts. I was just scanning through the other suggestions, and don't remember seeing it.
Try this:
Disconnect the battery for 1 or 2 minutes. Reconnect and see if all is well then. Good luck.
You may have already did this, but its worth a try.
Your cam has a 110 degree lode seperation which is a KILLER with computer controlled cars. A custom chip is a must. Your overlap in your cam is probably giving the computer fits at idle. I suggset talking to a chip guru to see if the rich condition can be programmed a out. Good luck with your vette. It sounds devilishly fast!!
Did you degree your cam? I'm beginning to wonder if you've got all that stuff taken care of.
You should be running a custom prom! But I can gaurantee you that the cam you have is very very mild. I would expect it to idle very very nicely. I've run the XE268 and the XE288. The 288 is radical but the 268 was silky smooth. Your cam is almost the smallest Comp makes.
yes my cam is degreed. I lowered my fuel pressure to 35 pounds. I couldn't lower it any more due to the adjusting screw backs up into the bottom of the plenum. Same problem. The block learn even sat at 2 for one key cycle. I had my battery disconnected several times allready. I don't think that will clear anything. When I ordered a prom through Wright, I gave him all my information about my build up. Including my cam specs. But I still would not be surprised if this is my problem. Does the chip provide the tables to read from in open loop as well as closed loop? I used my little blue point thermal laser gun on the outside of my ceramic headers and was only getting 375 to 425 degrees. I'm sure the inside will be hotter but how much? The O2 sensor needs 600 to 650 degrees if I remember correctly. My maf reading was right around 9 at idle. Which I think is right. There's not many other c4's where I live so part swapping is tough. Keep the ideas coming. If there's someone willing to talk me through everything I need to know about burning my own chip, then I'll order everything and get started.
