EVAP help
Old Feb 20, 2014 | 12:32 PM
YELLOW_95's Avatar
YELLOW_95
Default EVAP help
does anyone know where this is located:
DTC 26 - Evaporative Emission (EVAP) Canister Purge Solenoid Valve Circuit
Old Feb 20, 2014 | 01:18 PM
Mtn Billy's Avatar
Mtn Billy
Hi, use "Evaporative Emission (EVAP) Canister Purge Solenoid Valve Circuit" in a picture search in yer fav browser. You never said what year.
Bill
Old Feb 20, 2014 | 08:02 PM
YELLOW_95's Avatar
YELLOW_95
Bill
Sorry it's a 95 not sure if it's under the hood or in the rear some where
Old Feb 21, 2014 | 05:38 AM
toptechx6's Avatar
toptechx6
Assuming your 95 is the same as my 93 the canister purge solenoid is located under the right side fuel rail cover, see pictures below. (red and blue electrical conector) PCV air supply hose from throttle body to valve cover has been removed to show solenoid.
Old Feb 22, 2014 | 09:19 PM
YELLOW_95's Avatar
YELLOW_95
Thank this was a big help problem solved
To EVAP help
