What is the " pump shot"
Old Jul 14, 2002 | 11:33 PM
85WHITEZ51's Avatar
85WHITEZ51
Default What is the " pump shot"
A lot of you talked about this in my previous thread talking about tip in throtle responce. I would like to look into this topic more before I spend money on a new chip or computer.
Old Jul 15, 2002 | 12:31 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: What is the " pump shot" (85WHITEZ51)
With a carb setup there is a diaphram that pumps extra fuel into the carb throat when you suddenly pop the accelerator to mix with the added air inrush.
With an EFI engine this function must be done by the ECM when it senses a sudden change in throttle position. This is one reason why going to too large a TB bore can cause tip-in problems and hesitation on suddenly going to WOT.
Old Jul 15, 2002 | 12:48 AM
85WHITEZ51's Avatar
85WHITEZ51
Default Re: What is the " pump shot" (65Z01)
How can I correct mine? I have a stock TPI unit but it hesitates like mad upon WOT. Do I just need a new chip or do I need a new computer?
Old Jul 15, 2002 | 02:00 AM
65Z01's Avatar
65Z01
Try adjusting your TPS base idle voltage to 0.65Vdc (not over 0.67Vdc though) and the WOT voltage to as high as possible.
Then advance base timing till just below ping at WOT and high RPM.
Both of these measures will go a long way to enhancing throttle response.
[Modified by 65Z01, 12:05 AM 7/15/2002]
To What is the " pump shot"
