My 1993 LT1 doesn't idle consistently. When you start it dead cold it won't idle at all, just stalls out. Once it has run for a minute or two it was idle, very low (tach is below 500 rpm and it sounds like it is struggling to run). after the car warms up it idle's too high (tach stays around 1000-1200). If the car is warmed up and you start it it will idle at 650ish like it's supposed to but after you let it run, without touching the throttle the RPM's creep up to around 1000-1200.
I have replaced the IAC, found a broke wire going to the IAC so with that repaired I set the idle per the FSM, slightly depress accelerator when the car fires let go of throttle and run for 10 seconds, shut off for 5 and restart. i have checked for vacuum leaks all around intake manifold and there are none. i have checked all vacuum hoses, all the way to the firewall, no leaks anywhere.
Does anyone have any idea's as to where to go now?
But would a vacuum leak cause to not idle cold and idle fast hot? I don't have a way to measure iac counts. But when you turn the a/c on the rpms don't move, so at least I know the iac is working.
I haven't touched the idle screw, the IAC is new and throttle body clean. Unless I'm doing the idle relearn incorrectly... I'm out of ideas with this thing.
