Can you ID this wire????
Old Feb 22, 2014 | 07:04 PM
Ahnenerbe's Avatar
Ahnenerbe
Default Can you ID this wire????
I found this loose wire melted to the passenger side manifold and when I moved it and tried starting the car, it was causing a short. I need to know where this is supposed to go. Thanks again for your help.
Old Feb 22, 2014 | 07:11 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
Looks like knock sensor or coolant temp. sensor.
Old Feb 22, 2014 | 10:17 PM
Ahnenerbe's Avatar
Ahnenerbe
Since it's on pass side, it's not coolant temp. It looks like it would go to something close to the starter, so I assume it's a knock sensor. I can't find any diagrams of the knock sensor wiring, can anyone help with that? From what i have read it should go to a wire in the loom coming from starter, is that correct?
Old Feb 23, 2014 | 01:44 AM
WVZR-1's Avatar
WVZR-1
The year could help tremendously!
Old Feb 23, 2014 | 07:28 AM
TA's Avatar
TA
As others have suggested, it looks to be for the knock sensor or for the analog dash gauge, which is on the pass. side (at least on my year).
Old Feb 23, 2014 | 10:04 AM
Ahnenerbe's Avatar
Ahnenerbe
Duh, the year would help. It's a 84 crossfire. The wire looks to be brownish in color and goes to something by the starter.
Old Feb 23, 2014 | 11:07 AM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
If it's an 84 it's most likely the coolant temperature switch for the fan, located on the left of the dipstick..
Old Feb 23, 2014 | 12:08 PM
Ahnenerbe's Avatar
Ahnenerbe
I can't seem to find a diagram for this, can anyone help. It seems like it would be the knock sensor, it's located on passenger side on block. I can't find where the other end of the wire is so I need to see a diagram of what sensors are on that side. From what I understand the temp sensors for are on intake (for ecm) and drivers side block (for temp gauge). I ordered a shop manual so when it gets here I won't have to keep bugging everyone. Thanks again.
Old Feb 23, 2014 | 01:00 PM
ccrazor's Avatar
ccrazor
The knock sensor on an 84 is located lower in the block in front of the starter, the coolant temperature switch is to the left of the dipstick..
Old Feb 23, 2014 | 01:08 PM
ccrazor's Avatar
ccrazor
Fig 8a-10 shows location of both..
Old Feb 23, 2014 | 01:45 PM
Ahnenerbe's Avatar
Ahnenerbe
Thanks Ccrazor!! I went underneath the car and I see the knock sensor wire is blue (?) and it's cracked and fried just hanging down by the starter. This brown wire I show must be a temp sensor wire but I cant see any temp switch by the dipstick, might need a flashlight. I am starting to think this car is a basket case!! I rewired the fan relay (previous owners took the blue wire on fan relay and spliced to a orange wire heading to front of car) and I cleaned up some vacuum lines and now car runs like crap and barley stays running with a very bad miss and hesitation.
Old Feb 23, 2014 | 01:51 PM
Eike's Avatar
Eike
Should be there ...
Old Feb 23, 2014 | 02:33 PM
WVZR-1's Avatar
WVZR-1
If you look at the image 8A-10 you can see the tab that mounts the bracket that secures the "brown" wire that should be for the cooling fan switch that has been shown. It seems quite cut and dried.
Old Feb 23, 2014 | 02:38 PM
Ahnenerbe's Avatar
Ahnenerbe
Found it. Thanks for the help and the photos!!! Both the knock sensor and temp wires are fried. Time to replace.
To Can you ID this wire????
