Why am I am smelling fuel?
Old Jul 15, 2002 | 02:54 AM
gpagaduan's Avatar
gpagaduan
Default Why am I am smelling fuel?
The car has been sitting in the garage for eight weeks. It's going to the shop soon for engine work. Yesterday I notice a strong fuel smell. I checked for leaks but found nothing. Any ideas? I did have the gas cap off all this time but put it back on two days ago for no real reason.
:confused:
Old Jul 15, 2002 | 07:17 AM
jimbo10494's Avatar
jimbo10494
Default Re: Why am I am smelling fuel? (gpagaduan)
I just repaired my fuel smell. The problem was associated with a cracked (rotting) fuel vapor return line. The rubber line is located on the rear frame close to the drivers rear wheel well. Put your nose around the tire and sniff. If you smell gas the rubber return line is the culprit
The size of the OD is smaller than the fuel lines sold at the auto parts stores. I recommend purchasing the part from your local Chevy dealer.
Good luck, this is an easy fix. I put the rear of the car on ramps and had plenty of clearance to slide under the car and make the repair.
Jim
Old Jul 15, 2002 | 01:59 PM
ZR_TO_ENA's Avatar
ZR_TO_ENA
Also check the evaporator canister and the lines that are connecting to it. It is located in the front driver's side light well.
Good Luck
--John
Old Jul 16, 2002 | 01:10 AM
gpagaduan's Avatar
gpagaduan
Default Re: Why am I am smelling fuel? (jimbo10494)
Does the car just sitting contribute to the rotting of the line? :confused:
To Why am I am smelling fuel?
