CODES 23 and 34
Old Feb 24, 2014 | 07:16 AM
paintball2000's Avatar
paintball2000
Default CODES 23 and 34
I have the 1985 vet out this weekend and I was sitting at a light and noticed that the service eng light was on. I checked the codes and I got 23 and 34. im sure someone here will same me a lot of time and money in parts. im almost sure is going to be one of three parts Mass airflow sensor, TPS, or intake temo sensor.
Thank you
Old Feb 24, 2014 | 10:22 AM
vader86's Avatar
vader86
http://members.shaw.ca/corvette86/Code%2023.pdf
http://members.shaw.ca/corvette86/Code%2034.pdf
Fix the 34 first, I'd imagine the 23 will disappear after that.
Old Feb 24, 2014 | 10:40 AM
tunedport85inject's Avatar
tunedport85inject
i hope your MAF is good...anyway ceck the maf power relais/connector,and the signal terminal 998/ dk green to terminal b12 on ecm connector for short to ground or bad contact...
Old Feb 24, 2014 | 11:11 AM
paintball2000
Can a auto parts store check the mass airflow sensor on a machine like they do with say a ignition module?
Old Feb 24, 2014 | 11:19 AM
tunedport85inject
btw testing on car is easy,just read the pdf code 34,just 2 trial with maf connected and disconnected ,if you result in a 33 code you have a faulty maf...
Old Feb 24, 2014 | 12:47 PM
vader86's Avatar
vader86
No they won't know, You need to be able to check this one
Old Feb 24, 2014 | 12:52 PM
paintball2000
I am at work right now but when I get home I will try it. I have a feeling the mad is bad because the silicone gasket on the body is peeling and its not like gm cars aren't know to eat them like candy.
Old Feb 25, 2014 | 12:38 AM
Cliff Harris's Avatar
Cliff Harris
'85s don't have MAF power and burnoff relays, as shown in the link.
They have a MAF burnoff module. It has one relay in it that does both the power and burnoff functions. That might affect the troubleshooting process...
Old Feb 25, 2014 | 05:46 AM
tunedport85inject
Sorry, i miss you've an 85...i know, it's a different animal,i've one too...
Old Feb 25, 2014 | 09:11 AM
vader86's Avatar
vader86
Yes and the module is buried inside the dash, but studying the procedure should show to eliminate one culprit.
Old Apr 6, 2014 | 12:41 PM
paintball2000
I replaced the MAF and i still have the codes. Yes i cleared the codes and they came back. what is the next step to take on this one?
Old Apr 6, 2014 | 12:59 PM
tunedport85inject
i've seen the other thread you open where you talk about 23- 32,do you still have code 34 or was it cleared ?
if not you have still code 23-32-34,even after replacing the MAF ,do you confirm?
if you solved the 34 code with new maf,then yo still have 23-32 codes.
code 32 is a EGR system failure
code 23 is manifold air temperature (mat sensor) signal voltage high.
i'll post some pics from my 85 FSM
http://i809.photobucket.com/albums/z...ps83af9db5.jpg
http://i809.photobucket.com/albums/z...ps1ca10dd9.jpg
http://i809.photobucket.com/albums/z...psadaeb651.jpg
http://i809.photobucket.com/albums/z...psd9a49279.jpg
http://i809.photobucket.com/albums/z...psd47a32ae.jpg
http://i809.photobucket.com/albums/z...psd1a70da5.jpg
http://i809.photobucket.com/albums/z...ps7775b088.jpg
Old Apr 6, 2014 | 01:30 PM
paintball2000
i just disconnected the MAF and ran the car at at 2000 and it gave me a code 33 does that mean i got a bad MAF from supply ?
Old Apr 6, 2014 | 01:31 PM
paintball2000
if i connect the MAF and run the car normally i get code 23 and 32. most likely its my EGR?
Old Apr 6, 2014 | 01:45 PM
tunedport85inject
For some reason photobucket gives my pics upside down,save them and rotate using windows app.Its a 85' FSM.
Old Apr 6, 2014 | 01:49 PM
paintball2000
if i get a vacuum pump i should be able to see if its moving and if its holding vacuum correct?
Old Apr 6, 2014 | 03:02 PM
paintball2000
I got the vacume tester and went to pump it down and well it wouldn't pump down ....probly a bad diafram...should I do the fuel pressure reg when I pull the plentim off again ?
Old Apr 6, 2014 | 03:34 PM
DanielRicany's Avatar
DanielRicany
I Think Your Egr Valve Is Stuck Open.
To CODES 23 and 34
