1990 Corvette ABS Codes/Tech 1A Help
Old Feb 24, 2014 | 09:47 PM
Streamline's Avatar
Streamline
Default 1990 Corvette ABS Codes/Tech 1A Help
I am working on a 90 corvette, it has an occasional ABS light flash on the dash. I have a Tech1A scanner that I tried to read the code(s) with. I was wondering if anyone who has a Tech1A can offer me some assistance.
To my Tech 1A with a GM 88-91 Brake Application Cartridge(P/N TK03030):
I connected the 14 pin DLC Cable (P/N 02001392) to the GM 12/14 Pin DLC Adapter (P/N 02001384), Bosch ABS Adapter (P/N TA00022) to the DLC connector to the car.
The readout still stays to install the Bosch ABS Adapter.
Any assistance would be greatly appreciated.
Thank you
Old Feb 24, 2014 | 10:07 PM
leesvet's Avatar
leesvet
That's gonna be 'iffy' getting to read the ABS....
back then, they changed each week.
Mercedes, and other German cars used the exact same ABS...so they may have what you need.
The short answer to the lite....these often come on intermittently from dirty reluctor rings or corroded sensor tips. The tips also get damaged from worn out wheel bearings that allow the reluctor to lean in enough to knock off the sensor tip. Grease and dirt collect on things.
Another common problem is water draining from the hatch weather strip (corner)directly onto or INTO the ABS storage compartment....this causes the relays to corrode and/or fail. Plugs also get wet and dirty.
Old Feb 25, 2014 | 12:18 AM
RossyHusker's Avatar
RossyHusker
Did you try to jump the pins on the plug to see what code the dash gives you? You may not need the scanner to find out what is going on.
Old Feb 25, 2014 | 04:34 AM
toptechx6's Avatar
toptechx6
Thank you
Looking through a Tech 1 training handbook I found the following statement that may explain what you are seeing.
"If you are testing a 1990 VIN B.D, or Y body the Install Bosch ABS Adapter message will display as a reminder whether the adapter is installed or not."
To proceed with diagnostics:
Press F0=ABS Data List
Press F1=Code History
Press F2=Trouble Codes
Press F3=ABS Snapshot
Press F4=ABS Tests
Hope that helps.
Link here to some good ABS info, good luck troubleshooting.
http://www.corvetteactioncenter.com/...l#.UwxjZIWKU7k
Old Feb 25, 2014 | 09:50 AM
Streamline's Avatar
Streamline
Thanks for the information, mine is a convertible. I will check back in that storage compartment.
Old Feb 25, 2014 | 09:55 AM
Streamline's Avatar
Streamline
Press F4=ABS Tests
Hope that helps.
Thanks for the assistance. I do see the:
Press F4=ABS Tests
But when I Press any of those Functions on the TECCH 1A I get the message on the Tech 1A screen to install the Bosch ABS adapter (which is connected).
I was wondering if there is a specific application cartridge for ABS brakes or than the one I am using?
Old Feb 25, 2014 | 09:56 AM
Streamline's Avatar
Streamline
No I did not, I am trying to use the scanner since I have it.
Old Feb 25, 2014 | 02:40 PM
toptechx6's Avatar
toptechx6
Press F4=ABS Tests
I use the Mass Storage Cartridge with the most current software, but as far as I know the MSC simply utilizes the same programming that should be in your ABS cartridge. I have an ABS training manual but it is for later models, I will give it a look to see if there is anything that may help.
Old Feb 25, 2014 | 04:11 PM
milsurpman's Avatar
milsurpman
per the tk03030b instructions edited to make shorter. should be the same as yours with the addition on this one to include 92.
1.ignition off
2.cartridge in master slot
3.power up tech1a
4.if display is up insert 12 pin adaptor and bosch abs adaptor.
5. install in adl
6.ignition on
There is a warning if tech 1a isnt powered up and menu shown before adl attachment and power up of auto. damage can occur to tech1a.
I would very carefully clean all conections of your adl adaptors and the tech1a cable. Get a can at the radio shack of electrical contact cleaner. make sure all the male pins are clean. Your adl on the car is clean. Go over this very carefully. Maybe one of your adaptors is bad? Use some spares. I see bosch adaptors new in plastic on the bay. same with the 12-14pin adaptor. Later down the line get a mass storage cartridge. It saves swapping cartridges and wear on your tech1a cartridge connector. Hope you get it figured out as these are great tools to have especially when working.
Old Feb 25, 2014 | 04:54 PM
Streamline's Avatar
Streamline
Thank you...I have a MSC Cartridge, I have not tried it for ABS system. I will give it a try.
Old Feb 25, 2014 | 04:57 PM
Streamline's Avatar
Streamline
1.ignition off
3.power up tech1a
5. install in adl
6.ignition on
Thanks milsurpman...I have a MSC, I have not tried it yet, I had the Brake Cartridge and figured that would be the best one. I will look at the connections for corrosion, etc. Next up is the MSC trial.
Old Feb 28, 2014 | 10:43 AM
Streamline's Avatar
Streamline
FYI..Following up ....I tried all he suggestions (including using the MSC) still get the message to Install Bosch ABS Adapter.
To 1990 Corvette ABS Codes/Tech 1A Help
