85 fuel injectors
Old Feb 28, 2014 | 12:51 AM
dms0309's Avatar
dms0309
Default 85 fuel injectors
Hi,
I need to replace my fuel injectors on my 85
What are the best replacements to use, most dealers show the accell 24 lb injectors, are they ok or is there a better choice?
Old Feb 28, 2014 | 01:59 AM
Cliff Harris's Avatar
Cliff Harris
Check with FIC -- Fuel Injector Connection:
http://www.fuelinjectorconnection.com
Jon is known for phenomenal customer service and a LOT of people here on the Forum are customers.
Old Feb 28, 2014 | 06:13 AM
blackozvet's Avatar
blackozvet
I have bought a couple of sets of Jon at FIC for my 85 and can recommend him,
use the 24lb Bosch 3's - he has rebuilds for $189 a set and they work perfectly.
Old Feb 28, 2014 | 10:52 AM
John A. Marker's Avatar
John A. Marker
I have used the 24 lbs Accel injectors on my 85 with no issues. Jon at FIC -- Fuel Injector Connection has a very good reputation on this Forum for providing a good product and his personal support to get you up and running.
Old Feb 28, 2014 | 01:45 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Old Feb 28, 2014 | 05:53 PM
dms0309's Avatar
dms0309
Thanks everyone,
I checked out the FIC website and its good to know there are choices
The price for rebuilds looks good but for the long term is it better to go with new injectors or are the rebuilds as good as new?
Old Feb 28, 2014 | 08:25 PM
larryinalabama's Avatar
larryinalabama
I just bought asset of the rebuild bosh111 injectors from fuelinjectionconnection, they worked out great, they warranty the rebuilt ones for 3years
Old Mar 3, 2014 | 02:50 PM
playsdixie's Avatar
playsdixie
just went through this with my 85.....jon reccommeded 22# injectors at 43.5 lbs.....lots of disagreement on the forum regarding these injectors....
I installed them anyway....dyno tuned....they ran them at 32#..???,,,,called f.i.c. several times over this...they insisted 22# were now correct for an 85..... they seem to be working just fine...
Old Mar 3, 2014 | 03:29 PM
Zip Corvettes
First off the only new injector is the Accel injector and some like them and some do not. We have used lots of them here and there have never been issue. The Bosch III is a better injectors, they are not rebuilt that is a term that we all use, what is rebuilt is the injector is cleaned and new filter baskets are installed, that is the rebuild. You cannot disassemble an injector and do anything with the coil. I would personally on my own car go to the newer bosch III injector. However 24lb injectors are what is for a 85 and 85 only. In 86 you will need the 22 lb injector.
Old Mar 3, 2014 | 04:08 PM
playsdixie's Avatar
playsdixie
thanks for helping to clear up the issue.....manifold up on my 85 is off an 86, including tb and the 22# seem to be working great....originally called FIC and asked for 24# bosch III...don't know why they recommended 22#...working great anyway.....
Old Mar 3, 2014 | 06:39 PM
MrWillys's Avatar
MrWillys
85 used a 23.8 lb rated at 43.5 psi, but installed the at 39 psi. In 86, some used a 5235302 and were programmed at 23 lbs. 87 thru 89 used 22.4 lbs in the programming. 90 went to 22.1. Different pressures were used throughout these years to compensate for different injectors used. I totally agree with your rebuild comments on the injectors too.
Old Mar 3, 2014 | 08:02 PM
dms0309's Avatar
dms0309
I called Jon and he recommended the 22lb bosch 3, if you check out the TPIS website they recommend the 20lb bosch denso for the 85, say they will support stock to mildly modified engines from 230 to 350 hp. At this point I think it's a matter of trusting Jon's experience.
Old Mar 3, 2014 | 08:14 PM
MrWillys's Avatar
MrWillys
If an 85 car has a 17085050 rail ask john for Bosch 280-155-715.
Old Mar 3, 2014 | 09:18 PM
milsurpman's Avatar
milsurpman
My question is. Is the 85 injector rated at 24pounds at 35-39psi(not sure of exact 85 pressure) of the 85 fi regulator or 43 psi like the later regulators are set at?(shouldnt of posted this mr *****'s posted it right above. ) Thanks
Old Mar 3, 2014 | 09:26 PM
MrWillys's Avatar
MrWillys
Your injector should be a Bosch 280-150-223 which is 248 cc at 43.5 psi.
http://www.witchhunter.com/flowdatapix/b0280150223.jpg
If your rail pressure is 39 psi which is standard for the 17085050 rail these are a great replacement.
http://www.witchhunter.com/flowdatapix/b0280155715.jpg
From Jon:
http://fuelinjectorconnection.com/sh...p?productid=57
FWIW, 24 lbs is equal to 252 cc. If you check pressure it is done without vaccum applied to the regulator.
Old Mar 3, 2014 | 09:34 PM
milsurpman's Avatar
milsurpman
From Jon:
great info!
Old Mar 3, 2014 | 10:06 PM
Zip Corvettes
It depends on what that injector is rated at by psi. A 24lb injector is not just a 24lb injector. Was it rated at 39, 43.5 or 58? A 22lb injector will run in your car just fine, it will be lean up top if you do not install and adjustable regulator and increase the fuel pressure.
Old Mar 3, 2014 | 10:26 PM
MrWillys's Avatar
MrWillys
Let me clarify. 2.7 bar is very old and equal to 39 psi. 3 bar is 43.5 psi and not that old, and 58 psi is the newest at 4 bar. The injectors I listed were all rated at 43.5 psi, but can be converted here if you like.
http://www.csgnetwork.com/fiflowcalc.html
Please note if you convert the stock 280-150-223 from 248 cc to 39 psi it equals 22.5 lbs.
Knowledge is far superior to depending on someone who profits from ones ignorance.
Old Mar 3, 2014 | 10:47 PM
dms0309's Avatar
dms0309
if you wanted to make some mods like headers, 52mm t.b. and exhaust to increase air flow would it be a matter of increasing fp or going with a different injector?
To 85 fuel injectors
