3:07 ring and pinion
Old Mar 1, 2014 | 09:48 PM
dgantt's Avatar
dgantt
Default 3:07 ring and pinion
Any one know where I can pick up a set of 3:07 ring and pinion gears, for a 90 vette with the dana 36 rear end. I cant seem to find them anywhere. Its an auto with lots of upgrades, im about to order a set of AFR 190 heads as well. Is there a better set of gears, ive heard the 3:07's are the optimal gear for the TPI iengine. Thanks to all who reply.
Old Mar 1, 2014 | 09:51 PM
vetteoz's Avatar
vetteoz
Originally Posted by dgantt
Any one know where I can pick up a set of 3:07 ring and pinion gears, for a dana 36 rear end. I cant seem to find them anywhere.
Generally considered easier and cheaper to find a used diff head with 3.07 gears and just swap out the diff heads intact instead of paying the labor to set up new gears in your head
Old Mar 1, 2014 | 10:34 PM
dgantt's Avatar
dgantt
Yeah I found a few for sell like that for around $350, they were from 84-87 will that work on a 90?
Old Mar 2, 2014 | 09:11 AM
WVZR-1's Avatar
WVZR-1
All would "fit" but you would want to avoid an '84 - '85 build. The build changed and the short-axles, pinions and case are different. If you bought an '86 up you would have a few of the parts that break most frequently, the pinions, the center shaft and the short-axles for possible future use.
Old Mar 2, 2014 | 11:31 AM
dgantt's Avatar
dgantt
OK thanks,so what years do I need to be on the look out for for this swap that I will have no issues. Thanks
Old Mar 2, 2014 | 08:29 PM
WVZR-1's Avatar
WVZR-1
Theoretically any build '85 or newer should have the same case, pinions and short-axles but to be safe I'd try for '86 or newer. The build information that "MIGHT" be etched into the bottom of the housing would be a confirming piece of documentation.
605260-2, 605260-4, 605321-4, 605490-2 would be later product.
To 3:07 ring and pinion
