I have a 87 corvette with manual weather controls. When I put fan speed on high the AC fuse blows. I replaced the relay and the resistor but it still does it. I've read a lot of other forums and they say to check the inline fuse but I cannot find it. I don't know if this matters or not but when the car is off I still have power at the red wire going into the relay. That's all the info I have. So why do I keep blowing fuses and how do I fix it. Thank you
Put 12V to motor from battery to check with a maybe 3AMP or 5AMP fuse. Will it run? Does it get hot? You haven't replaced the switch? Actually an '87 with manual AC the relay is powered with a "fusible link" rather than an inline fuse, like Cliff mentioned. Do you have an FSM? Should be simple enough to check the "red" wire at the relay with a test light. Is it powered? If yes it's NOT a fuse or the "fusible link. You have the lower speeds with out problems? You mention you've checked and have power to the relay at all times so you've eliminated that aspect of the problem.
The red wire goes directly to the battery through a fusible link. It has power on it at all times.
In the last 15 years my fan went bad 2 times. First time it just quit. Nothing looked wrong. Second time, the fusible link went up in smoke. The car does have 168000 miles on it so Im not complaining.
Thank you everyone for the replies. But I don't think the motor is bad because i am fine on the 3 lower speeds. And I ran power directly to the motor from another battery and it will run just fine. It's just when I'm inside the car and I go to turn it in high it instantly blows the fuse.
Buy a "blower switch" if you feel the relay, resistor and motor are fine. Simple as that I'd believe!
I bought a blower motor and still same thing so it looks like I'm buying the switch. Let you guys know what happens
I wouldn't just keep replacing parts until you find the right one, that's how you cost yourself a lot of money.
Get yourself a multimeter, set it to ohms, measure the resistance of the high fan speed circuit. Through the wires and switch, you should see no more than 0.2 ohms. If you see more than that, trace it down by measuring resistance of the circuit in segments and replace/repair that item.
Edit: Or, trace down the whole circuit and see if you find an area where the wire or switch shorts to something else.
