87 and engine still cutting off
Old Jul 15, 2002 | 05:35 PM
kbligh's Avatar
kbligh
Cruising
Default 87 and engine still cutting off
I cannot get this resolved. Engine is shutting down while driving. Thought it was the fuel pump. It was replaced. I changed out the ignition module as a suggestion from a different member who had a similar problem. The MAF and power relays were replaced as shown by the codes. If you pull off to the side of the road, put it in park it will start right back up. You cannot restart in neutral after the engine has cut off while coasting.
Hoping for an answer! Thanks
