Head gasket leak
I almost finished assembling it and was putting in the antifreeze using an evacuator and fill tool when I noticed it wouldn't hold vacuum.
I put a pressure tester on it and located a lot of leaks around the intake, and then I filled it with water and pressurized the system and it is leaking out of both sides of the head, on both heads, right at the gasket.
So, what gasket should I get now to replace this one so it doesn't leak? I'm very pissed off at this point because it was $30 bucks for each head gasket, plus $30 for a set of intake gaskets.
I need something that won't leak but will be pretty decent for quench.
Thanks.
He said that I shouldn't use the Fel Pro 1094 for street use.
He said I should look into a graphite gasket because it expands and contracts better.
I wasn't able to find a graphite gasket, but I did find one made of composite.
He said it was okay to use, but I just want to get some more input. Is a composite gasket okay to use with my build?
And another thing, this gasket is 0.028", which would make my quench area 0.052".
He said that quench on a street application is not as important as it is for drag applications. He said that should be fine for up to like 600 horsepower.
I read online that quench area stops being effective at around 0.060" - 0.080".
Is my quench going to be okay with 0.052" instead of 0.039" which it was before?
It also is lowering my compression from 10.3:1 to 9.99:1
I plan on running 93 octane.
Thanks for the help.
Were you the one who used an abrasive disc grinder to clean the old gasket material off the block?...
If so, The block is probably warped causing all the leaks...
Edit:
You are the one, I found your post.
http://forums.corvetteforum.com/c4-t...questions.html
I think that may be the reason why it leaked. But I think the new gasket I have will be better because as I'm told the 1094 is meant for engines that are torn down frequently.
Only question though that concerns me, since I used an abrasive disc on the deck, it is all over the internet that the material gets into the rings and into the oil and isn't filtered by the filter and causes premature bearing failure.
I used an air hose to blow out all the dirt and stuff from the rings, and I got a lot of what was in there.
Do you guys think that my bearings will fail? If so, what can I do to stop that from happening?
Thanks.
You shouldn't have a big issue with anything getting past the rings and into the oil. The oil filter will trap that stuff. Definitely do an oil change and replace the filter ASAP.
But as mentioned, your earlier use of a cookie (and I assume an air grinder) on the block deck may be the big problem. If a head gasket (regardless of which one it is) won't seal, then don't worry about quench area, compression ratio, or bearing life as you will be looking at removing the engine and getting the block deck machined.
Is there a tool rental place or maybe an AutoZone store where you can rent a machinist's straightedge? That will tell you if the block surface is straight. And there is nothing wrong with the FelPro 1094 gasket.
The surface feels smooth, and you can't grab a finger nail on anything.
Also, I had drained the oil before I cleaned the deck, and it already has new oil and filter. So now I have to change it again, plus I'll have to order more ZDDP additive. :/
edit: Well I know when I use red thread lock both surfaces are clean and oil free, so it can do it's job.
I got the bolts out. There wasn't any sparks when I used the cookie. And I really didn't want to pull the motor out and have it decked, because then while I have it out I'd have it rebuilt, but I don't have the money for that right now. And if I was to have it rebuilt I would go to a 383. And I really don't have money for that either.
Why do you want/need ZDDP oil additive? I can see it when breaking in a new engine, but for amount of miles on your motor, just use a good grade of full synthetic oil. That should be all you need.
Permatex for sure.
