Help identifying ground effect...
Old Mar 5, 2014 | 04:07 PM
S S0DEN's Avatar
S S0DEN
Default Help identifying ground effect...
1988 Corvette Z51, I am missing the Passenger side, door ground effect, I have the lower ground effect in place and the bracket to attack the door ground effect is in place too.
I have the build sheet from CM, would it list the actual body kit from the factory?
Here is a few pictures, maybe someone knows. It appears I am also missing the front piece, either the air dam or some ground effect that goes there too, I have a few studs sticking down from the front piece and no air dam under the car.
Old Mar 5, 2014 | 04:14 PM
c4cruiser's Avatar
c4cruiser
There never was any sort of GM-produced ground effect kits. They were all aftermarket. What you have in the looks like part of the Greenwood package. But the Greenwood name would have been molded in.
Similar styles were sold by the various Corvette accessory catalog companies (Eckler's, Mid America, ZIP, etc.). You may want to take the passenger side piece off to see if there is any reference to a manufacturer.
Old Mar 5, 2014 | 04:41 PM
S S0DEN's Avatar
S S0DEN
I didn't think to take the Passenger bracket or lower molding off, I will do that and see if there is any markings.
To Help identifying ground effect...
