effect of mods?
Old Mar 10, 2014 | 05:11 PM
Rohn's Avatar
Rohn
first....how do you do that?
http://www.thirdgen.org/techboard/di...uide-book.html
Old Mar 10, 2014 | 08:50 PM
MrWillys's Avatar
MrWillys
Honestly guys, turn off the egr, and air and it should be good. If the VE tables are worked smooth there should be no hard start. Open loop tables work off closed loop learned function which should smooth out. Yes, it does default to an open loop map above 91.9 KPA or WOT, but otherwise it's closed loop operation. Starting should be based of last shutdown plus added start parameters. Sounds like $700 bought inexperience that may know OBD2, but is lost in old speed density.
Playsdixie, you can do this yourself really. See here:
Www.scotthansen.net/data.html
There's some software cost outlays, or if you datalog I'll help you.
Old Mar 11, 2014 | 06:35 PM
playsdixie's Avatar
playsdixie
thanks so much for the info...but bear with me a little...although I install automated wiress control systems for pool equipment, i'm not that computer friendly...you are saying I can hook a laptop up to my car..and read what the tuners see?....aside from a laptop, what is the relative cost of the software?....and any other equipment.....is it user friendly?.....and of course..."datalog"????j....thanks...Paul ...
Old Mar 11, 2014 | 07:36 PM
MrWillys's Avatar
MrWillys
The Moates cable is $80, and the software is free for the first 20 datalogs, and $90 if you want to buy it. I like modifying my bins using Tunercat which I believe is about $100, and the Moates burn2 for burning you're own chips is another $80. So, for $260 you can do it yourself. More importantly, is for what you paid it should be perfect. Cold starts should be perfect after smoothing the fuel maps. All of this is shown on my links page. Myself, and many here can always help too. If you read the page I created it takes you step by step on how to tune speed density. It doesn't include custom spark tables based on different cam profiles, but yours should operate well on a stock one.
Old Mar 12, 2014 | 06:31 PM
playsdixie's Avatar
playsdixie
thanks....that cost is mimal ...since i'm keeping it, seems like a good choice.....The garage that dyno'd it wants to take one more shot at it next week.....after that, and eventually anyway i'll be contacting you for specifics....thanks again....Paul nam 67=68
Old Apr 17, 2014 | 03:47 PM
spro2395's Avatar
spro2395
removed the smog, egr crap , installed headers/ roller rockers..had it dyno'd....
engine runs great with one exception....on initial start it takes a minute or two to run smooth...purrs like a kitten when warm....since I live in s fl...it's not a big problem...any thoughts on what it could be? new everything above the block....idle wavers....just a couple of minutes....then steady at
650 ,,,,any thoughts would be appreciated....Iac valve is new...Paul
How much HP did you pick up on the dyno from your mods?
Old Apr 17, 2014 | 04:26 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
What is the TPS value at normal (600rpm) idle?
What is base timing set at?
Did you add an AFPR to bump fuel pressure or do all the bumps in chip?
From the dyno tune plot what is the A/F ratio?
What year Vette?
Old Apr 17, 2014 | 06:30 PM
playsdixie's Avatar
playsdixie
What year Vette?
85 ...rechecked the timing....way off....reset the tps, tire smoker now...
sometimes best to do it yourself.......estimated 50 hp increase with the work....
Old Apr 17, 2014 | 06:54 PM
S S0DEN's Avatar
S S0DEN
Paul nam 67=68
Thank you for your service Paul.
Old Apr 18, 2014 | 06:43 AM
playsdixie's Avatar
playsdixie
thank you....unfortunatly the real heros are not here to accept accolades....I hate the war, but it sure makes you realize how great America is, even with its faults....
Old Apr 18, 2014 | 08:31 AM
WW7's Avatar
WW7
Paul, Glad you got it straightend out.......These guys on here are great at helping figure out problems..They're very tenacious.........WW
Old Apr 18, 2014 | 08:55 AM
S S0DEN's Avatar
S S0DEN
I agree 100%.
Old Apr 18, 2014 | 05:00 PM
  #33
playsdixie's Avatar
playsdixie
without the forum, that old wreck I bought last year wouldn't be the tire smoker it is now....with a fsm and these guys, i'll always be able to do all my own work...and keep it running sweet as suger...hopefully some day i'll be able to contribute with the information these guys have....they are the best paul
Old Apr 18, 2014 | 06:38 PM
  #34
65Z01's Avatar
65Z01
tire smoker now...
Congrats on the success; enjoy...
Old Apr 18, 2014 | 09:32 PM
  #35
playsdixie's Avatar
playsdixie
this is the result of forum advice.....don't need to say more..
