Help with troubleshooting.
Old Mar 6, 2014 | 05:01 AM
MickeC4's Avatar
MickeC4
5th Gear
Default Help with troubleshooting.
Hi!
I am new at the forum and is looking for some tips =)
I have got a few (minor?) problems with my c4 vette (88),
Prob1: It drives rough at low rpm's and when you floor it, it judders before taking of. I was thinking i might be the fuel injectors?
Prob2: When revving the engine, toe and heal driving etc it makes a high pitched sound (only for a second).
Prob3: If i leave the battery in the car for about a week it will be flat, if I disconnect the battery its fine.
Any ideas?
(I apologize if there is allot of spelling and grammar mistakes)
Old Mar 6, 2014 | 06:19 AM
hcbph's Avatar
hcbph
Default Issues
I'm no expert but these are the steps I'd start out with:
1) try some chemical cleaner like Seafoam or other product you add to the gas and see if that helps. Also check that no wiring is loose.
2) Sounds like that might be the serpentine belt, check it out.
3) Try disconnecting the battery for the same length of time and see if it dies. If it doesn't, connect a meter between the cable and battery and disconnect each fuse till you find where the draw is, that's the circuit to check out.
Old Mar 6, 2014 | 04:27 PM
vetteoz's Avatar
vetteoz
Start by pulling the engine fault codes and see if anything showing
http://www.corvettephotographs.com/c4vettes/codes.htm
report back what you find
Old Mar 7, 2014 | 01:28 AM
Cliff Harris's Avatar
Cliff Harris
Many times this is caused by a vacuum leak.
There are lots of sneaky ways for the air to get in, like an EGR valve that is stuck open. Dried out and cracked rubber vacuum lines. Broken vacuum check valve. The little plastic vacuum lines can touch something hot and melt.
Old Mar 8, 2014 | 07:06 AM
MickeC4's Avatar
MickeC4
5th Gear
Thanks for all the answers, I will check it out when I get back home (about 2 weeks) and report back! :
Old Mar 8, 2014 | 10:57 AM
Mtn Billy's Avatar
Mtn Billy
#3. This can drive you crazy. An easy check is to remove the courtesy lite bulbs or at least run the car check and see if their hot.
Old Apr 18, 2014 | 11:30 AM
MickeC4's Avatar
MickeC4
5th Gear
Default error codes
Hi I finally managed to get home and pull the error codes, I got:
(flash,flash,flash,flash,flash (pause) flash,flash,flash,flash) times 3.
followed by code 12 times 3 and then the same sequence repeated over and over again. I have no idea what this means and i can find nothing on the internet, any idea? (do you think I have to take the codes again)
/Micke
Old Apr 18, 2014 | 12:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Three "12"s followed by three more "12"s means there are no stored trouble codes.
Regarding Problem 1:
Check manifold pressure (vacuum) for any vacuum leaks.
Check fuel pressure, with vacuum line disconnected and plugged. It should hold steady if you blip the accelerator.
Check for a bad spark plug/wire.
Verify base timing is between 6-8 deg BTDC, with connector open in the Blk/Tan wire near the brake booster.
Old Apr 18, 2014 | 01:18 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
For the battery, disconnect the negative cable and connect a meter set to amps scale with one lead to the battery and the other to the cable. You are looking for a reading of less than .05 amps. If you get higher you need to start pulling fuses as suggested earlier to find which circuit is giving you the problem. When you have the door open to check fuses you will need to fix the door switch for the lights and wait for them to time out before you start..
To Help with troubleshooting.
