Wheel hub bolt T55 torx
Old Mar 8, 2014 | 01:11 PM
paintball2000's Avatar
paintball2000
Default Wheel hub bolt T55 torx
Does anyone know the part number for the rear wheel hub bolt that is a T55 torx. Every place i call gives me a diffrent part number and half of them think im asking for the studs for the wheel hub. I have a 1985.
Thank you
Old Mar 8, 2014 | 01:17 PM
paintball2000
since im on a parts finding kick does anyone know what the part number is for the stablizer link in this picture.
Old Mar 8, 2014 | 07:42 PM
WVZR-1's Avatar
WVZR-1
Thank you
GM # 14046943 is the hub bolt 3 per side for '87 and earlier. There looks to be some on eBay presently or you can do a WTB in the "C4 PARTS".
The stabilizer link in your image is top and to the left. If the link itself is OK you can do bushings.
The link GM 10052272 would come with insulators and is still available. The insulators are still available also but the link is a better buy. GM 14060114 for the insulators, you need 2 for the sway-bar ends in addition to the link to do the job. 1 link and 1 insulator per side!
Anything else?
Old Mar 10, 2014 | 11:18 AM
paintball2000
Thank you for the information. I found new bolts for this and they are no longer torx at menards.they are m 12 75mm in length 10.9 hardness and are 1.98 each. EBay wanted 40.00 for three so save some time and money
To Wheel hub bolt T55 torx
