speedo not working properly
Old Mar 9, 2014 | 01:02 PM
t.bick's Avatar
t.bick
2nd Gear
Default speedo not working properly
I'm having a problem with my speedometer/fuel gauge/odometer essentially the LCD part of my 90 vette it is fully illuminated all I see is 8s for every number and full fuel gauge any suggestions where to start?
Old Mar 9, 2014 | 03:49 PM
Larry/car's Avatar
Larry/car
Try disconnecting battery to reboot system. I recommend rebooting anytime some abnormal electric display has occurred. Works quite often, after all most systems are computer controlled.
Old Mar 9, 2014 | 04:35 PM
t.bick's Avatar
t.bick
2nd Gear
I've already tried that and had no luck unfortuantely
Old Mar 9, 2014 | 08:13 PM
hcbph's Avatar
hcbph
Default Gauges
Depends on whether the display is ok or not. Assuming it is, I'd start checking out the wiring, especially the grounds to insure everything is going where it should. Include checking various connectors when checking out the wiring.
To speedo not working properly
