Replace Sensor plugs on motor
Old Mar 10, 2014 | 05:03 PM
7d8's Avatar
7d8
Default Replace Sensor plugs on motor
Anyone know where to buy replacement plugs for engine sensors? Recently replaced motor in my 85 vet. Every sensor plug end crumbled. I was able to push the pins back into the female end and hold them in with RTV sealant, but would like to replace all of the broken plugs. Checked local auto store with no luck.
Old Mar 10, 2014 | 05:14 PM
STL94LT1's Avatar
STL94LT1
http://eficonnection.com
Old Mar 10, 2014 | 05:27 PM
7d8's Avatar
7d8
Originally Posted by STL94LT1
Thanks..... Love this forum.
Old Mar 10, 2014 | 05:31 PM
don hall's Avatar
don hall
Originally Posted by 7d8
.............would like to replace all of the broken plugs.
Replace all sensor, broken, or not. Amazon provides a wide selection for shopping purposes.
Old Mar 10, 2014 | 05:33 PM
WVZR-1's Avatar
WVZR-1
When using that link "click on pieces" after you ID the connector. For the majority of what you need you should be able to use a release tool and only replace the shell rather than pigtails that require cut splices. There are less expensive but if you're somewhat new to it all EFI isn't a bad place to shop.
Good luck!
Old Mar 11, 2014 | 11:27 AM
mixalive's Avatar
mixalive
NAPA also sells them.
To Replace Sensor plugs on motor
