1984 vacuum system
Old Mar 10, 2014 | 05:55 PM
Phallet's Avatar
Phallet
1st Gear
Default 1984 vacuum system
I am trying to figure out the vacuum diagram on my 1984 corvette, 5.7L, automatic. Is there somewhere that I can get a diagram/schematic for this. So far it is a mystery to me.
Old Mar 10, 2014 | 08:23 PM
ex-x-fire's Avatar
ex-x-fire
Autozone web site has a bunch of diagrams. Did you google "1984 Corvette vacuum Diagram"?
Old Mar 11, 2014 | 03:54 AM
Cliff Harris's Avatar
Cliff Harris
There is a lot of crossfire information here (and a vacuum diagram):
http://chevythunder.com/cross_fire_i...n_19821984.htm
Old Oct 17, 2015 | 01:17 PM
drew#46's Avatar
drew#46
2nd Gear
my name is drew#46, I'am doing the same thing on my 84 l83 motor
I haven't been able to find anything yet, was wondering if you have had any luck?
Old Oct 17, 2015 | 02:02 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Did you follow the advice and links provided by the good posters above?? If you had, you'd have seen this:
Old Oct 17, 2015 | 10:28 PM
Hot Rod Roy's Avatar
Hot Rod Roy
That's the same diagram that's on the radiator shroud of my '84. But that leads me to a question about the vacuum routing I've never been able to figure out: There are two vacuum motors on the two air inlets to the air cleaner, but only one of those vacuum motors are controlled by the temperature sensor, the one for the warm air tube. Does anybody know why the other one would be routed directly to the throttle body vacuum? I would think this inlet air path should stay open unless the engine is very cold.
Since this is an educational thread about the '84 vacuum routing, I hope this isn't considered a "hijack question".
Old Oct 17, 2015 | 10:48 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That's a good question! "I GOT THIS!" -followed by a loud bang, and a muffled scream
My guess is that the passenger's side closes off completely when there is vacuum, forcing all the air to enter the filter housing through the driver's side only; hot air pipe when cold and through the driver's side "cold air" pipe when hot...opening the throttle (depleting vacuum), opens both flaps pulling through the (semi) CAI hood ducts.
Old Oct 19, 2015 | 08:24 PM
Hot Rod Roy
Phallet and Drew, have you figured out your vacuum hose routing? Where are you having trouble?
Tom, I'd say you're right on how the air cleaner vacuum motors work, but that doesn't answer why. I decided to do some investigation on my '84. I discovered that my passenger side vacuum motor has a busted diaphragm, so that side never closes! So I'm drawing nice fresh, cool air thru both hood ducts all the time! No wonder the car runs so good!
That explains why I have no trouble keeping up with a multitude of ZR-1's and a certain hot rod 409!
Old Oct 19, 2015 | 08:55 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Sure it does! You know the principle of the heat stove; to draw hot air in when the engine is first started, (cold), to help vaporize fuel better. Most cars have one filter inlet, so you have one valve, temp & vacuum actuated. You car has TWO inlets (which is why it keeps up w/ZR-1's!) so if we only closed the driver's side, we'd still be sucking cold air through our passenger's side hood CAI...dramatically diluting our hot air just when we need it to be the hottest. SO, we throw in another flap in the passenger's side that closes w/vacuum.
Now, any time we're at idle, vacuum closes the passenger's flap, we're drawing all air through the driver's side...and that side determines air temp through the thermactor temp vacuum switch. If motor is cold, all of that driver's side air will be heated, if the engine is warm all of that driver's side air will be cold, though the hood.
One inlet is probably way more than enough to feed a stock L83...but still, when you go to WOT, you get both flaps open, feeding MASSIVE, COLD, ZR-1 BEATING air into the filter housing!
Old Oct 19, 2015 | 10:06 PM
Hot Rod Roy
Tom, I'm glad you have a good sense of humor!!
Old Oct 19, 2015 | 10:38 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Hey, I try! Sometimes...it even shows!
Old Oct 20, 2015 | 01:03 AM
whalepirot's Avatar
whalepirot
Oh, we were having a contest? Yeah, your car runs fantastically.
I spoke with my old tuner, Gary, and he loves to tell the story about how he drag-raced a well-known Corvette engineer at a national Corvette gathering. That engr. always brought the soon-to-be-released new model year Corvette, for show and intro, in this case an '89.
That slightly modified '84, with a TBI similar to yours, Roy, beat the '89 TPI handily.
To 1984 vacuum system
