From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Door hinge spring, how hard to change?...
Opened the driver's side door on my 89 this morning and heard this "pop" and metal hitting the ground. Picked up the metal piece and found out it was the top hinge spring. The door works fine but it will not stay open or lock into place when open. Does the door need to come off to replace this? If not what's the easiest way to replace this? Thanks.
Re: Door hinge spring, how hard to change?... (89ragtop)
i just replaced all my door hinges(must repaint). i bought them from gm for like $25.00 each...including the spring that fell out of yours. very easy to change if your car is apart but if it is not the spring replacement is best. if you could move the door up & down (holding it on the bottom) your hinges are shot.good luck! :cheers:
