Quick opti question....
Old Mar 17, 2014 | 12:14 PM
ChrisWhewell's Avatar
ChrisWhewell
Default Quick opti question....
My 93 still isn't starting. Fuel pressure good, fuses all good, injectors have pulse, drained tank put new fuel in, new fuel filter, MAP sensor tests good. I crank it and it almost starts, like it wants to start but just doesn't quite start. There is spark, but i'm wondering maybe opti is bad ?
I have a spare optispark unit from a 95 LT1 vette, motor had 25k on it when rod bearing went. The opti looks new but been sitting in garage in a box 4 years. Any reason I would not want to swap to this one ? It has the vent nipple on it. I think I read where optis are different , different years. Does anybody know if the '95 opti is a direct drop-in replacement for the '93 opti, or are the drives different or some other reason I can't swap one for the other ? Thank you very much
Old Mar 17, 2014 | 12:57 PM
bassackwards's Avatar
bassackwards
Won't fit, drives are different
Old Mar 17, 2014 | 01:03 PM
01 Coupe's Avatar
01 Coupe
From: Denton, TX My goal in life is to be as good of a person that my dog already thinks I am.
Like Bass said, drives are different for the '95 and "96's. Besides optis are never a quick change and if you are not sure that's the problem you are creating a bunch of work for yourself. Just my .02.
Old Mar 17, 2014 | 01:08 PM
dizwiz24's Avatar
dizwiz24
cant he convert his motor to use it?
Id rather convert to use a new old stock gen 2 opti vs. Buy some piece of crap china gen 1 optispark. Though you might be able to pay top dollar and find a new old stock gen 1 optispark if you look hard enough.
The vacuum vented setup, of the gen 2, should work better. Way more reliable setup... Though you can/should easily convert a gen 1 to vented setup.
I have my 93 converted to use a gen 2 optispark. I had to so i could use the lt4 extreme duty timing chain kit.
I also put a new cam in.
My memory is failing right now (its saint patricks day) And i cant tell you all the parts i needed to do this.
Bassackwards, werent you the guy in TN that i sold my old new old stock optispark, with custom vent, to?
I bet its still working good!
Old Mar 17, 2014 | 01:29 PM
STL94LT1's Avatar
STL94LT1
List of parts to convert his 93 to a gen II opti.
Gen II vented opti
Opti vaccuum harness
Opti wire harness
Gen II timing cover
Camshaft change
Old Mar 17, 2014 | 03:26 PM
ChrisWhewell
thanks ya'all, I was afraid of that. Too bad the drives aren't interchangeable. By the time I change opti and pull the manifold for a cam change, I"m thinking I might just as well pull the motor to make it all easier. I just wish I could get her running again
Old Mar 17, 2014 | 03:29 PM
DanielRicany's Avatar
DanielRicany
If you spray some starting fluid through the intake, do you get a different response from the engine? Almost likes its firing up?
Old Mar 17, 2014 | 04:00 PM
dizwiz24's Avatar
dizwiz24
If you gotta do a cam change, now is a good time to do hotcam mod.
I would have traded you my old new old stock gen 1 opti w/ custom vent harness for this opti you have - if you would have posted this in 2012!
Old Mar 17, 2014 | 08:45 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Well...you checked at least ONE of the critical elements required to start and engine...ave you checked the other? Is there good fuel pressure?
Old Mar 18, 2014 | 07:32 AM
ChrisWhewell
No. Yet, there's spark at the coil. But, different plug wires , when I put a spark plug in the boots and crank it and observe them, the spark is visibly different on some than others
ChrisWhewell
41 psi
Old Mar 18, 2014 | 08:33 AM
bassackwards
It's still in a box on the shelf.
OP if you have good spark at the coil and erratic coming out it could be the opti. I bought a car that wouldn't start and turns out the rotor fall off.
Your cap off the newer opti will fit the older one.
Old Mar 24, 2014 | 08:25 AM
ChrisWhewell
Thanks. I'm pondering switching drives between the opti's, wondering if that's viable.
Or, get a new opti. In that case, oh great, another search and re-search. Help !! Anybody know what source is a good replacement opti for a '93 ??
Old Mar 24, 2014 | 09:39 AM
lt4obsesses's Avatar
lt4obsesses
Okay, so we have good spark at the coil, and erratic spark at the plugs.
This tells me that your opti, at least on the low resolution side, the optical sensor, is functioning.
First, double check your plug wire connections, use a little dielectric grease on them. Also double check that all the wires are in the right place, as it can be easy to cross them at he opti. (I'd bet you already have, but it's worth stating) Particularly the connection of the coil wire going into the opti, it can be difficult.
It could be the distributor cap and/or the rotor. One of the main reasons they converted to a vacuum based vented design was the build up of gasses from the electrical spark that would cause the terminals to corrode.
Old Mar 24, 2014 | 09:47 AM
ChrisWhewell
Fudge it, I ordered an MSD 8381, $499 including overnight shipping only $25 extra. I'll button it back up and hopefully that was the problem, if not I won't worry about the Opti anymore for a while.
Old Mar 24, 2014 | 06:03 PM
dizwiz24's Avatar
dizwiz24
If that optispark from the 95 w/ 25000 miles is oem, I will buy it.
Old Mar 25, 2014 | 06:39 AM
ChrisWhewell
OEM, yes. Its off a 95, the motor threw a rod bearing, motor had 28k on it, or 25k, I forget which. Its been in a freezer bag in my garage about 5 years. the resin looks nice shiny newm the bearing is tight, rest of it looks fresh. I have another opti off a 100k motor, its bearing is noticeablly loose, but its good for parts I guess. agent[at]inventorweb.com or 512 763-1142
To Quick opti question....
