C4 track car
Old Mar 17, 2014 | 06:29 PM
emptnest's Avatar
emptnest
Default C4 track car
I intend to buy a c4 for track duty, and prefer newer. That said, I have found two candidates: a 96 LT4, but with base suspension and exhaust; and a 93 LT1 Z07 with headers. Both are ZF6.
So what are the pluses and minuses of each? Will it be less expensive to upgrade the suspension and exhasut of the 96, or the engine of the 93?
I am a newbie to the track, but I want a car that can be modded to grow with me as my skills improve.
Old Mar 17, 2014 | 08:47 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
A hot cam swap in the LT1 car would be cheaper than suspension upgrades to the LT4, and likely net you more hp.
If it's really going to be a track car, you're probably going to replace all the suspension on either car anyway...and likely go through the motor too...so I'd buy which ever car is in better overall shape.
Old Mar 17, 2014 | 09:08 PM
carguy604's Avatar
carguy604
If you're going to track the car, you really want the Z07 assuming that both are in roughly equal condition. The base car and the Z07 handle totally different with the Z07 being much tauter. It also has bigger brakes.
Old Mar 17, 2014 | 09:09 PM
SpedRacr93's Avatar
SpedRacr93
I would start off with the 96 LT4. The engine is superior enough in materials and technology to the early LT1 to make it worthwhile as you upgrade and make changes. For a full out track car, you will swap suspensions out on both cars anyway to be competitive.
Your modifications will be dependent on the type of track events you plan to run anyway.
I'm assuming you're trying to stay in a certain budget but if I were you, I would also look into a C5 Z06 before I bought a C4 as a track car. I have been tracking C4s for years and I love the cars, but if I didn't already have them and were looking for a solid platform, that is where I would start.
Old Mar 17, 2014 | 09:10 PM
SpedRacr93's Avatar
SpedRacr93
All 96 Corvettes have 13" brakes, so the brakes are the same on both cars.
Old Mar 17, 2014 | 09:23 PM
emptnest's Avatar
emptnest
Default Please keep the comments coming
My goals on the track are just to have fun, and to learn to use the full capability of the car. Competition is only with myself, not other drivers. I guess that would make me more a hobbyist than a racer.
Ignoring future mods, starting budget is under $10k, and the lower the better (to pay for those futuremods).
Old Mar 17, 2014 | 09:29 PM
383vett's Avatar
383vett
Does this include the car?
Old Mar 17, 2014 | 11:22 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Have you tracked cars before or will this be your first one? If you are learning pick either one and leave it alone. Learn the car and how to control it at speed before making changes. A well handling car will be easier to control at first but teach bad habits and be harder to control when you pick up speed.
Old Mar 18, 2014 | 09:19 AM
89C4TunePort's Avatar
89C4TunePort
I ran into the same problem. I bought my first car and was always at the track. what I did was kept the car all stock(89 6 speed) I learned every in and out of the car, now that I understand the car I'm making improvements to better my self at the track.
keep us updated on how it goes!!
Old Mar 18, 2014 | 12:31 PM
Sidney004's Avatar
Sidney004
LT4 if you go the C4 route.
Old Mar 18, 2014 | 08:00 PM
l98tpi's Avatar
l98tpi
Max G’s
I agree LT4 and 96. You will change the suspension components as you progress in either car. If the LT4 doesn't have the J55 brakes, it isn't much if you know where to look to convert them. There are higher rate springs available versus the Z07 also.
Old Mar 19, 2014 | 11:23 AM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
Having gone from a street C4 to a track C4, built entirely by myself, I highly recommend purchasing a car that's already done. It will cost roughly 2-3 times more to build than to buy.
Old Mar 19, 2014 | 12:10 PM
Churchkey's Avatar
Churchkey
I would get the LT4, stiffer springs are not the fast way around a corner.
Soft springs with good shocks & LARGE sway bars = fast corners.
Run it as is until your able to get all it has to offer out of it. If you stay with it you will want coil overs, Banski (sp) rear linkage, better brakes/tires etc. You can add HP, a gear, cage etc later.
Suggest a driving school so that self taught methods that will be 100% wrong will be eliminated.
To C4 track car
