D36 or D44 ?
Old Jul 16, 2002 | 06:30 PM
ALLR RED's Avatar
ALLR RED
Default D36 or D44 ?
I also have a rear end question. I have a 93 LT-1 auto, I'm looking to upgrade from my 2.59 gear set to a 3.54. I have read some of the other entries on this subject but I haven't been able to determine an answer from what I've read. How do you determine if you have a D36 or D44 style rear end ? Also, I am an ex-automotive tech (23yrs. in the business) and have set up many rear ends in the past. I curious as to how most of your changes have been done. I mean have most bought the complete carrier from a supplier or have most of you replaced it yourself or had it done. I have the tools and the know how and figure I could save some bucks but I was just wondering how most of you got it done.
Old Jul 16, 2002 | 06:32 PM
scorp508's Avatar
scorp508
1984 = All Dana 36
1985-1996 : Stick = 44, Auto = 36
It can be done at home as long as you have experience setting up rear ends and have the right tools for the 44.
Old Jul 16, 2002 | 06:34 PM
95AquaC4's Avatar
95AquaC4
Default Re: D36 or D44 ? (ALLR RED)
I had mine done. 2.59's to 3.54 is a HUGE difference!! Your gonna love it!! :D
Old Jul 16, 2002 | 07:23 PM
J Z06's Avatar
J Z06
Default Re: D36 or D44 ? (95AquaC4)
I'm with 95AquaC4.
A former 2.59 owner :U wth we're they thinking( :rolleyes: I know, gas mileage..but you get my point) putting those pathetic gears in our cars? Even with my torquey motor, it kinda lugged. I had such a grin when the D44 and 3.45's went in! NIGHT and DAY.
Old Jul 16, 2002 | 07:32 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
Just did mine last week - from 2:59 to 3:55 plus a 2800 stall speed
converted :D U will luv it :yesnod:
:cheers:
Old Jul 16, 2002 | 11:11 PM
CFI-EFI's Avatar
CFI-EFI
As Scorp508 pointed out, you have a model 36. The lowest gears Dana
made for the 36 were the elusive, 3.31's. Unless you buy after market
gears made for a 2 series case, you will have to change your diff case,
also. By "diff case", I am refering to the internal case that the ring gear
bolts to. The same situation applies when making a similar ratio change in
a 44. I can provide the exact point where the cases change if anyone is
interested. Good luck.
[Modified by CFI-EFI, 9:14 PM 7/16/2002]
Old Jul 16, 2002 | 11:17 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
I did my D44 recently. I used the following tools to set up the rear.
Bearing separator, press, 3/4" drive socket set for the pinion nut and for pressing in bearings and races, inch pound torque wrench with three socket drive adapters (1/4 to 3/8, 3/8 to 1/2, 1/2 to 3/4), 5/8" brass punch., angle iron to bolt the carrier case to, two C clamps to hold the angle iron to the work bench, dial indicator and holder, caliper for measuring shims, 500 ft lbs air impact wrench for use on the bearing puller and torquing the pinion nut, two prong (can use three prong also or one that can be bolted to the bearing separator) gear puller. I also needed a four foot pry bar to tighten the pinion nut. The gear set I got came with a crush sleeve. The stock gears use shims to set the pinion preload instead of the crush sleeve.
Old Jul 17, 2002 | 12:30 AM
vader86's Avatar
vader86
go to 3.54's if you have to do a fair bit of hwy driving, 3.73s if you just do city stuff mostly
Old Jul 17, 2002 | 09:08 AM
ALLR RED's Avatar
ALLR RED
Default Re: D36 or D44 ? (vader86)
Yea, I pretty much decided on the 3.54 set up I think it will give me what I'm looking for without being to radical. I very aware of of how gear changes affect the launch of your vehicle. In my drag racing days I used to run 5 and sometimes 6 series sets. Thanks to all who responded you've been a big help.
To D36 or D44 ?
