screwed up the starter wires i think?
Old Mar 19, 2014 | 08:46 PM
sansonic's Avatar
sansonic
Default screwed up the starter wires i think?
Getting closer to getting this thing to run again. I ran into a problem. I was going to connect the negative terminal to my battery and its sparked like crazy. I think i wired the started power cable to a transmission bolt on accident
Does anyone know what wires go to the starter exactly?
Old Mar 19, 2014 | 09:10 PM
vetteoz's Avatar
vetteoz
Year?
Early years have the main batt POS cable and some power wires off the main solenoid stud
Old Mar 19, 2014 | 09:33 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
The main wire from the battery is black , plus I believe at least one red fusible link to the large solenoid stud and a smaller purple wire to the "s" terminal..
Old Mar 20, 2014 | 03:25 AM
Cliff Harris's Avatar
Cliff Harris
This is what my starter solenoid connections look like:
Old Mar 20, 2014 | 07:32 AM
WW7's Avatar
WW7
On my 89 all the wires in the harness go to the large stud, except the purple ( small) ignition wire goes to the small stud.( As in the picture above)..WW
Old Mar 20, 2014 | 09:09 AM
sansonic's Avatar
sansonic
Its an 86 and yep i definatly wired that big wire to the trans... wow thanks guys i feel dumb
Old Mar 21, 2014 | 03:06 AM
Cliff Harris
I looked through the FSM and found that the small red wire is actually fusible link K. It is used for the HVAC blower fan.
If C60 it goes to the fan relay.
If C68 it goes to the blower control module.
Old Mar 21, 2014 | 10:17 AM
383vett's Avatar
383vett
The op might want to do a load check on the battery. I did a good sparky years ago and it killed a cell in the battery.
Old Mar 22, 2014 | 09:41 PM
sansonic's Avatar
sansonic
She turns over real good now i dont think i hurt anything to badly.
Old Oct 29, 2023 | 11:17 AM
SMM_DREW's Avatar
SMM_DREW
Default I screwed up mine too
I got a big old thick black wire that I can extend to both the passenger and drivers side it’s pretty long. I’m not sure where it goes, can someone share pics of their starter wiring on an 87 and help me solve the black wire issue?
To screwed up the starter wires i think?
