87 4+3 Overdrive
Old Mar 23, 2014 | 12:33 PM
abenton's Avatar
abenton
Default 87 4+3 Overdrive
Replacing my o/d unit next week. Any tips/info on the process would be appreciated !! Special tools ??
thanks
ab
Old Mar 23, 2014 | 12:49 PM
powerpigz-51's Avatar
powerpigz-51
I replaced my 85 unit with a 88 unit, did it all by myself. No special tools, but I think I did have to grind the outside wall of a socket down on a bench grinder to access one of the bolts that holds the 2 units together. There is also a washer(s) between the 2 units that you have to get onto the input shaft of the OD when coupling the together. I stood my tranny straight up and down when taking it apart and re-attaching. The girder thingie was a real biatch to bolt up to the diff and tranny, but it was doable with regular wrenches.
Old Mar 23, 2014 | 07:25 PM
vetteoz's Avatar
vetteoz
http://www.corvetteactioncenter.com/...Overdrive+Unit
To 87 4+3 Overdrive
