battery
Old Mar 23, 2014 | 01:26 PM
nicpete's Avatar
nicpete
Default battery
hello all
whats better to use for winter storage a battery tender or a trickle charger??
thanks
Old Mar 23, 2014 | 01:48 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Battery Tender is a brand name.
Trickle charger is a device.
All battery tenders are "smart" trickle chargers.
But not all trickle chargers are "smart".
As long as the trickle charger your using is "smart", they are good.
Smart means they have the ability to shut down charging and "maintain" battery.
Battery Tender brand isn't the only ones that have this ability though.
But they might be the most well advertised.
Old Mar 23, 2014 | 06:49 PM
nicpete's Avatar
nicpete
thanks for the education,i appreciate it
Old Mar 24, 2014 | 07:13 AM
AirForceOne!'s Avatar
AirForceOne!
Here's the battery tender I have used the last 2 years with no issues and the best $39 you can spend in my opinion!
http://batterytender.com/battery-ten...-at-0-75a.html
Old Mar 24, 2014 | 06:52 PM
nicpete's Avatar
nicpete
just picked one up,thanks
Old Mar 24, 2014 | 09:41 PM
SJW's Avatar
SJW
Here's the one I use:
And here's how I connect it:
Live well,
SJW
Old Mar 25, 2014 | 05:33 AM
nicpete's Avatar
nicpete
Live well,
SJW
great thanks for the info
Old Mar 27, 2014 | 12:12 AM
Vetteblack-96's Avatar
Vetteblack-96
Several years ago I bought a few of them for my car, bike and jet ski. They were about $20.00 each at WalMart. At the time they had two different brands for sale. For some reason or other, I didn't like going thru the lighter. Always hooked up to the battery terminals. Paranoid I guess.................
Old Mar 27, 2014 | 12:21 AM
S S0DEN's Avatar
S S0DEN
A friend of mine did this with his late 80's Z28 during winter storage through the liter and it melted one of the wires and popped the fuse... Used the terminals after that.
Old Mar 27, 2014 | 01:02 AM
Vetteblack-96
Thanks, S-Soden! Now for sure I won't use the lighter. Hate to learn thru somebody else's bad experience, but Thanks for the tip.
Old Mar 27, 2014 | 10:59 AM
SJW's Avatar
SJW
I don't know what your friend was doing, but the charger I use can only furnish 1.5 amps of current. This is typical of such battery maintainers, and it's not enough current to melt any wires feeding a lighter socket, or pop the fuse protecting this circuit, even with a direct short circuit to ground. And the fuse in your friend's Z28 should have prevented any wires from melting in any case, unless somebody had installed a fuse with a higher rating than should have been in this circuit.
I have rigged up identical chargers with lighter plugs for several friends, and neither they nor I have had any problems whatsoever, over the course of many years of use, and there's no reason they ever should. The fuse that protects the lighter circuit provides an additional margin of safety, as compared to connecting a charger directly to the battery with no fuse in-circuit, and that's one of many reasons I favor this approach.
Live well,
SJW
To battery
